Hi
I would like to know what are the tools you most like to use to sand curves.
The discussion comes from another thread that I do not want to hijack.
Maarten wrote that is one of the uses for his MF70 Proxxon Milling tool.
That is a great idea.
I was planning to use this :
I still have not done the setup. But if someone have used that accessory, it will be nice to know.
PT-2 asked:
I wonder if the bearing in a small drill press are stable enough to do the same. . . problem is that the handle to bring the bit down would need some rigging and a foot treadle or device to lock it in place for the sanding. Any recommendations???? Rich (PT-2).
And Brian077 wrote : I have an oscillating spindle sander with different sized heads for sanding .
I would like to see what do you use and what could be the answer to PT-2.
Thank you !!!
Daniel
PT-2 asked:
Thank you !!!
Daniel
