While i still investigate/testing other options to make the chainplate straps as they are presented on the above picture and to keep the momentum going, i decided to go with old, trusted way of making a straps - two wires soldered together.
First, start with twisting the wire around object that has diameter slightly smaller than deadeyes..
Insert the deadeye..
Apply small amount of soldering paste..
Add solder, previously flattened...
Solder it with a mini torch..
Make sure deadeye stay correctly and that strap is flat..
All of them are done, no extras...
Clean them up with 1000 steel wool
Color them with a flat black paint...
The opposite end of the strip, was flattened a bit by squeezing it and a small hole was drilled thru. This hole is for a pin that will be used to hold the strip to the ship.
Start installing them on the ship making sure they follow the rope line...
Small touch up paint job will be required as well..
These are casualties from my attempts.
Will use most of wires as pins in the future steps so it material is not quite wasted.
Happy modelling..
Happy modelling..
s were tied to the cable....
