very much en angle-Lower rail for the quarterdeck and upper poop. An upper rail will be installed that will go above each of the cutouts for the cannon. Same goes for the forecastle carronade bow chasers.
quarterdeck SUPERLower rail for the quarterdeck and upper poop. An upper rail will be installed that will go above each of the cutouts for the cannon. Same goes for the forecastle carronade bow chasers.
Weather deck planking complete. One coat of stain and then a quick wash of acetone to tone it down a bit. I might scrub with some more acetone tomorrow after it dries completely. I like the gray-ish look better than an in your face wood look of a weather deck.
Next will be the upper rails and waterway/scuppers. That'll take a couple of days to do it right.
a good beginning, Mate. one question: What are these cut in the false deck for?
Very nice, I personally like the wood stain look. I did this on my Bluenose and love the colour.
Finished with the forward pin rack and that leads directly to the timbers to close up the bow. Temporary gammoning in order to lay the timbers around an 8mm sized dowel that will eventually become the bowsprit. One more little curved timber at the top will finish it. View attachment 202497View attachment 202498View attachment 202499
happy 2021. well, build. only a few will do the bow pin rail curved the same way as the deck-WELL DONE.Bow closed up and ready to accept the bowsprit when it's finished. Forward pin rack with belaying pins.
Forward upper rail on the port side. Quite tedious sticking to the plans rather than simplifying the rail supports but the end result is worth it. I spent about 4 hours on this rail alone. As I have the process down I'm certain the fore larboard rail will go quicker.
As I have already commented on your Deck planking, no further comment. What is new is to see the gunports rigged correctly. Few are doing it this correct way.happy 2021. well, build. only a few will do the bow pin rail curved the same way as the deck-WELL DONE.
Did that threaded rod come with the kit or was that your own purchase? Very nicely done.
So a nice add on to the kit. Did your kit not come with the caronades or were they just not very good?Caldercraft sells mini kits, cannon/carriage and caronade/sled kits. The threaded rod was in that mini kit. Two complete caronades for about $12.
