Thank you MustafaYour Bounty looks very good my friend.
Fantastic! You have done a beautiful job here!Copper sheeting is complete (except the rudder) Hull is painted to the final colors, after copper sheeting the rudder, green copper patina will be applied (as copper get's green patina in salt water)
Last two pictures show method of producing copper plates- strips cut off on my modified guillotine marked with pin-wheel stamped at predefined length to make copper plates...View attachment 204910View attachment 204911View attachment 204912View attachment 204913View attachment 204914View attachment 204915View attachment 204916View attachment 204917View attachment 204918View attachment 204919View attachment 204920
Gracias JoseImpresionante, tu no eres un aficionado al mendelismo eres un profesional.
UN SALUDO
That looks very realistic. Excellent job on this. Thanks for sharing your process.After some testing and experimenting, I finally got natural looking copper corrosion/ patina in salt water.
First, copper was brushed by wire brush on Dremel, than cleaned from grease and impurity, than used white vinegar to get non-shining reddish oxide, than used copper/brass black to get darker and partially irregular brownish patina, and than carefully applied Copper green patina to get spontaneous, irregular layers of green copper oxide.
Compared results to naturally corroded copper sheets and I am pretty much satisfied with similarities and result...View attachment 205653View attachment 205654View attachment 205655View attachment 205656View attachment 205657View attachment 205658
Thank you very much Uwek. These pictures definitively assured me that I was not much wrong deciding how to weather copper sheeting. I checked a lot of pictures and researched a lot before applying chemicals and patina, but these are amazing pictures from this site. I breathe much easier nowLooking very realistic! f.e. comparing with the hull of the USS Constitution
View attachment 205688 View attachment 205689
A Rare Sight - USS Constitution Museum
Dry Dock 1 in the Charlestown Navy Yard, where USS Constitution currently sits undergoing repairs, was considered an engineering marvel when it opened in 1833.. . .ussconstitutionmuseum.org
