HMS Bounty 1:60 scale scratch build
looking impressive - i'm taking a keen interest and lots of notes for when I have a go at the part completed 'del prado' one I bought.
THank you guys for your attention and nice words. I am glad you like and follow my work. I shall try to put as many as possible picures and explanations of the work on this site, hopefully someone would find it helpful, or would get new ideas.
Copper sheeting is complete (except the rudder) Hull is painted to the final colors, after copper sheeting the rudder, green copper patina will be applied (as copper get's green patina in salt water)
Last two pictures show method of producing copper plates- strips cut off on my modified guillotine marked with pin-wheel stamped at predefined length to make copper plates...IMG_20210111_012503.jpgIMG_20210111_012521.jpgIMG_20210111_012532.jpgIMG_20210111_012546.jpgIMG_20210111_012603.jpgIMG_20210111_012612.jpgIMG_20210111_012625.jpgIMG_20210111_012643.jpgIMG_20210111_012656.jpgIMG_20210109_122322.jpgIMG_20210109_122437.jpg
Last two pictures show method of producing copper plates- strips cut off on my modified guillotine marked with pin-wheel stamped at predefined length to make copper plates...View attachment 204910View attachment 204911View attachment 204912View attachment 204913View attachment 204914View attachment 204915View attachment 204916View attachment 204917View attachment 204918View attachment 204919View attachment 204920
Fantastic! You have done a beautiful job here!
Impresionante, tu no eres un aficionado al mendelismo eres un profesional.
UN SALUDO
Impressive, you are not a fan of mendelism you are a professional.
A GREETING
After some testing and experimenting, I finally got natural looking copper corrosion/ patina in salt water.
First, copper was brushed by wire brush on Dremel, than cleaned from grease and impurity, than used white vinegar to get non-shining reddish oxide, than used copper/brass black to get darker and partially irregular brownish patina, and than carefully applied Copper green patina to get spontaneous, irregular layers of green copper oxide.
Compared results to naturally corroded copper sheets and I am pretty much satisfied with similarities and result...IMG_20210115_001304.jpgIMG_20210115_001323.jpgIMG_20210115_001332.jpgIMG_20210115_001342.jpgIMG_20210115_001356.jpgIMG_20210115_001404.jpg
Compared results to naturally corroded copper sheets and I am pretty much satisfied with similarities and result...View attachment 205653View attachment 205654View attachment 205655View attachment 205656View attachment 205657View attachment 205658
That looks very realistic. Excellent job on this. Thanks for sharing your process.
Looking very realistic! f.e. comparing with the hull of the USS Constitution
View attachment 205688 View attachment 205689
Thank you very much Uwek. These pictures definitively assured me that I was not much wrong deciding how to weather copper sheeting. I checked a lot of pictures and researched a lot before applying chemicals and patina, but these are amazing pictures from this site. I breathe much easier now :D
