I've had this kit in my stash for quite a few years and I think it's finally time to build it. I know that the kit is chock full of inaccuracies, it's missing a deck Mamoli modeled 3 decks instead of the correct 4), there is a cannon on the main deck (probably added to create display interest), the pumps are the wrong type (looks like they used the style they were changed to in the mid-1800s), there's no plumbing below the pumps, a brace is missing from the hold bottom, and probably a host more.
However, I don't care, I'm not building it for a museum piece but to hone some of my skills and as a nice display piece for my office. I really like that it models the full main mast rather than just a stub mask that some of the larger scale models use. The only changes I'm planning to make are, 1) scribing joint lines on the outside frames to add both realism and visual interest, and 2) maybe carving and adding the brace in the hold.
I plan to follow the build instructions with a few exceptions to make it easier to model. I'll build the frames flat (add spacers to each frame individually) and then stack them. I also intend to build and populate each deck separately, then slide them in like drawers and add the final details. That will make it much easier to add all of the details to each deck and do final assembly from the bottom up so I don't have to try to place items between decks with a tweezer. After all, it's 1/93 scale so pretty small.
And away we go....
Dominick
And away we go....
Dominick
