Milling your own parts sell definitely take you to a higher and more satisfying result than a laser cut kit package. Your computer skills serve you well. Rich (PT-2)This is by the way the amount of plywood I used for the hullView attachment 209940
Very good idea / solution and performance..... are these parts also cnc-cut?
Looking forward to seeing that upgrade, thanks for sharingit's 4 mm and I have to do 4-5 passes. Each bulkhead took me about 10-15 min per pass.
I'm replacing the diode now, the lens and the air compressor, so hope for better performance
