love your detailed explanations and your modeling skills.
Hi Bill, Thanks for posting your experience here. I completely agree with you, I’ve found Euromodels to be a bit of an enigma, as a kit they are a bit wanting and sometimes very frustrating. I don’t know why but like yourself I’ve found that so far they have been the most satisfying and enjoyable models that I have built, the Ajax so far is no exception. I only have a small bench sander, saw and a couple of drills as well as a small selection of hand tools yet I was able to build the Royal William, I think to a fairly high standard, it is shown in the finished section. I want to do the Mordaunt next but at the moment for me it’s looking a bit too expensive, and yes I found that their support was excellent.Hi all
I’d like to put my 2 cents worth in on the discussion on Euromodel.
Over the last 40 years I’ve built the kits from the major companies and have been very satisfied with the results. Years ago I was told at my local hobby shop that Euromodel kits were to difficult to build as they had no instructions so I avoided them. But I wanted more of a challenge so I bought the Friedrich and downloaded piratpetes manual. I soon discovered that I would need a scroll saw, band saw and sander plus wood if I was going to build something more than a Kit ship. I got a box of walnut and oak off cuts from a cabinet shop and to make a long story short made all the wooden parts according to the very detailed plans
Sometimes it took me longer to figure things out than to make the part but I ended up with the most satisfying build I’ve ever done and the most pleasing ship to look at.
My next project when time permits is the Falmouth which I was able to get before they had to temporarily close shop and the Royal William was not available.
If I had built this from the kit supplied wood I would have been somewhat disappointed but thanks to having me take it up a notch it became a real labour of love and learning. The after sales support was excellent and they are my company of choice from here on at my skill level
Bill
Hi Bill,Hi all
Bill
Hi Don. Yes that mahogany was lovely. I do intend to put a light teak wood stain on the hull just to give it a bit more colour, I’ve done this on other models and find that it works wellLooks good Ken, although, not the beautiful mahogany of your last build!Going to look great!
Hello Everyone. Today’s episode is the finishing off the first planking with a good sanding. I hadn’t shown the progress on the first planking as I’m trying to catch up so you only got to see the start and finish, but I’m sure that you’re all familiar with this process and that you have your own techniques. The basic hull ended up pretty good, true with no undulations so a quick sand showed me where to fill and it was only small gaps between some of the planks, These when filled and with a robust sanding saw the hull as perfect as I was ever going to get a first layer. I was only able to do this as the plans supplied for the shaping of the bulkheads must have been perfect, for that I officially forgive Euromodel for the issue with the stern. I started to line the inner wall, none of this will be seen but I needed the depth for the port linings to look right. You’ll see the small clamps that I use, these are the best that I have ever come across, they have a reasonable depth, a very wide throat and a strong spring. I got these from a garden centre, they are for clipping to garden canes, the wide throat is for a flower to pass through. Because it is not for modelling they were very cheap, a large bag full for a couple of pounds. Next post will be the cutting out and lining of the gun ports, see you then
You may notice that the keel and prow are in place, I’d forgotten about doing these at this stage, that’s the problem with doing a post at a later date, the brain doesn’t always follow. I cut a channel for these in the planking to just slot them into, then both nail and glue. I’d checked and shaped the prow early on when I could lay the keel flat so I didn’t expect any problems but with modelling something always comes up and bites your bum. I’d pre drilled the holes for the nails, I glued the parts in then when in place I gave the nails holding the prow one last tap for luck, the prow to my astonishment shattered into about five pieces. Sod’s law, I asked myself why I couldn’t have just left well alone. This was the first time that the age of the kit had had an effect, the wood used for the prow was now dry and brittle, it had broken where the cross grain was at its thinnest, I was able to do a repair without it being noticeable no harm done but I must be more careful. I’ve checked all the other wood and it seems to have been the only piece to have been affected like this.
Hi Bluebeard.. Yes they look similar, as you said a good price, I bet that if it said, ‘for modelling‘ it would be five times the price, thanks for your likes.I just found this handy clamps here:
A bargain 40 pieces for $9.00
ken
Ken, a very honest and basic approach to planking that produces a good outcome. Well done. PeteHello Everyone. Progress continues apace. Today’s post is to tell you about my second planking. I don't intend to do what many do and shape each plank to a set pattern, carefully measured into sections, adding scarfs and stealers so that each plank ends up the same. I tried that once and found that I couldn’t master it and the end result looked poor, a bit of a mess with not perfectly fitting edges. I much prefer the planks to end up smooth, flat and tightly fitted to its adjacent plank with not the slightest gap, they may not be correct to the purists but to my eye it looks better. I know I will end up with the dreaded tapered to a point planks but I will arrange these so that the wale covers the pointy bits and all should look well, to my satisfaction anyway.
The planks are 5mm x 1mm and are nicely machined. Because of the age of the kit I found that although they were still nice and springy the wood was very dry and prone to having small splinters coming away, so I had to be careful with them. I don’t use a holding cradle or hull clamp when planking, I find that these prevent you from getting at the hull from all angles and hampers you. I just put a pillow on my knee and rest the hull on that, you can move it around easily to come at it from any angle just like wresting with a small dog.
I started my planks by running the first just above the gun ports, the width of the recess and the second just below the ports then I planked in between them cutting and sanding them to the exact size so that it leaves the correct gap for the port recess, it may feel like it takes longer but there will be no cutting out for the recess which can often lead to a slightly imperfect edge. With that section done I continued down tapering each plank slightly and fixing until I thought the pointy planks would then run to under the wale then started from the keel upwards. I use cyno on all my second planking only doing small lengths at a time, pressing down into place then when set moving along to another small section. I leave the planks standing upright in a thermos flask of hot water for at least ten minutes before I use them. I only needed to use my nippers for the bow curves but for the stern as the curve was pretty severe I needed to use a soldering iron. A good thing about cyno is it activates with moisture so still works well with damp planks. So far, so good
Looks great Ken!Hello Everyone. Again thanks for your responses to my posts. Today I’m showing you my completed second planking. All went exactly as planed with no issues, the planks being nice and tight against each other and with an acceptable flow to them. There are rather a lot of pictures but they show the sequence of finishing. I could have stretched these out to a few posts but as I’m trying to catch up I’m throwing them all in together. The first couple show after putting the planks on, then after sanding, and finally with the wale attached. I gave it a coat of light teak wood stain, as I mentioned I don’t like the dull greyish colour of walnut and I think that the stain warms it up a bit. I was very pleased that the wale hid the pointy planks as I’d planned and I think that it all came out ok.
View attachment 215347View attachment 215348
Hello Everyone. Thanks for your interest. I have attended to the placing of the canons, first having made one up. The carriages provided weren’t up to much, as you can see they were straight sided rather than tapered towards the front and they were oversize. To get them more correct I cut them down the middle, chamfered them then glued them back together and sanded the front and rear level. I’m not going to spend time accurately detailing them as only the rear part will be seen. You’ll notice that the one shown in the picture has a strip glued to the wheels, this is to compensate for the height where no deck planks were laid. When the upper deck is in place I won’t have access to most of the canons so for these I’ve made up cradles and will place the barrels on them through the ports.
I made up and fitted one of the capstans and as you can see a set of stairs. I made up from the plan and fitted all the beams which support the upper deck then test fitted the deck and masts, adjusting where needed, I’ll fit these much later after I get some of the detailing done. I have shown a picture from above of the balsa block that I used to shaped up the stern.
Hi Bluebeard, I can see your point, but I didn’t explain properly, I won’t be adding that strip when they’re fitted, it was just to compensate for the un planked part whilst I was setting up all the canons, when they sit on the planked deck that piece won’t be needed as they will then be the right height. Thanks for your compliment.Ken:
Great progress. It’s looking fabulous.
About adding a strip to compensate, how about adding bigger wheels. I don’t think it will be noticeable.
But then again, Im just an intermediate, you are the Pro. and knows better.
Good work you are doing.
