I agree on water and CA, wet wood sticks better than dry in my experience with it (at least with the ones I have used)
I wet my parts with accelerator spray before putting in place.I agree on water and CA, wet wood sticks better than dry in my experience with it (at least with the ones I have used)
Slow patient bending with a light touch is essential for my own bending. Nicely done for your first. RichI don't have much experience but my first planking and second layer planking went well using little brass "add-on" i've made for my temperature controlled soldering iron. Even cherry 2x6mm plank i was able slowly bent to shape. Gluing wet planks with tidebond wood glue and using same iron on lower temperature to "dry" the glue. Planks didn't change color, ironed glue is holding as good as natural dry.
View attachment 218269View attachment 218270
This is esentially what I do too. I also use accelerator spray as needed on particularly difficult parts. If I had to wait for PVA glues to fully cure, my build would take months!I use gel CA. Start at one end with a drop of gel CA...work across the curve using drops of the gel CA. I hold the plank in place with my finger for a ten count as the CA gel sets and move on to the next glue point...repeat...
CA and PVA glues are quite compatible. Using PVA with gel CA as a "tack" allows the plank to be fixed in seconds...then move on to the next. Because of the PVA he plank will still hold in the event of a vibratory or concussive force on it...a weakness of CA glues as a class,This is esentially what I do too. I also use accelerator spray as needed on particularly difficult parts. If I had to wait for PVA glues to fully cure, my build would take months!
You have the same problem with PVA glues. I use TiteBond for full size furniture construction. If you plan to stain, you had better get every single spot of the glue off the wood, because, once dry, the TiteBond will not allow ANY stain to penetrate. The only way to remove it is to chisel/plane it off, down to bare wood again.I would use CA cautiously, some of the blends (if not most) penetrate the wood and create blobs. You will hard time stain\oil this spot. Even after painting it will leave the ugly spot. I would test the CA glue first.
I've used Titebond I,II,III for over 25 years here and have done woodworking for almost 60 years. Squeeze out is always a consideration. Setup time is an issue in modelling to me. So, I'll stick with CA. I've seen no emperical data on CA failure or issues concerning longevity. We'll see what happens....You have the same problem with PVA glues. I use TiteBond for full size furniture construction. If you plan to stain, you had better get every single spot of the glue off the wood, because, once dry, the TiteBond will not allow ANY stain to penetrate. The only way to remove it is to chisel/plane it off, down to bare wood again.
It is a little bit different behavior, Dave. CA penetrates the wood and you absolutely cannot remove it (unless replacing that piece). With TiteBond, those spots on top, and can be removed while wet or scrape when dry. For my modeling purposes, I never use TiteBond 1,2, and 3. Most times I use Elmer's MAX and LinecoYou have the same problem with PVA glues. I use TiteBond for full size furniture construction. If you plan to stain, you had better get every single spot of the glue off the wood, because, once dry, the TiteBond will not allow ANY stain to penetrate. The only way to remove it is to chisel/plane it off, down to bare wood again.
I don’t use TiteBond either. I use WeldBond. Stays somewhat flexible and squeeze out is easy to deal with.It is a little bit different behavior, Dave. CA penetrates the wood and you absolutely cannot remove it (unless replacing that piece). With TiteBond, those spots on top, and can be removed while wet or scrape when dry. For my modeling purposes, I never use TiteBond 1,2, and 3. Most times I use Elmer's MAX and Lineco
