With such a scale, it will be tough to represent caulking correctly. Maybe bevel each side of the plank, then the gap between adjacent planks will give the shade for the caulking. I would try an 'H' grade pencil as well.
Hello Jim, For your white caulking I suggest that you use white paper of the thickness of your caulking. An example of this is Zoly's Ontario build on his post #769. Just a thought, have a look.Ok guys. I'm going to throw out a question for all of you just to see if anybody has any better ideas than I have to solve a problem. The problem is with the decking, and as I mentioed earlier I think I have a solution but I'm not going to divulge it at this time to see what you might come up with. The decking on this ship is teak with lead caulking and is 3 1/2 " wide. Now at 1/64th scale that would mean that the planks themselves would be less than 2mm wide. Then there is the matter of the caulking. Remember, this is being built as a SCALE model, not an opproximation. I want to keep the decking at scale. Any suggestions?
