Tightly served. What size is the block? RichIt's only my first try using this little tool.
But it's worked a lot better than most of my previous efforts
Jan
Jan
I am down in the 2.4 to 5 mm sizes which are likely to small but let me know how something down around 5 works for you. Thanks. RichHi Rich,
The block is 9mm. I‘ve not tried any smaller ones but with enough practice I’d expect the same result. I used a light color thread for the serving to get a good look at the result.
Jan
OK, I can do that. I've got some 4 and 5mm blocks that I need to redo.I am down in the 2.4 to 5 mm sizes which are likely to small but let me know how something down around 5 works for you. Thanks. Rich
Recently took delivery of a couple of these tools.
I noticed your post #26 where you resorted to trapping your thread with tape.
A small tip:- the folded flat in front of your tape is an inbuilt feature to do just that.
Hallo @ThanasisHi all.
As a long time ship modeler and member in quite forums, I keep seeing that the issue of an easy way of seizing, is most wanted.
It was also for me but after many experiments, I ended up to the below method.
See what I mean.
As many of you, I also like fishing, so I came across the tool which allows you to tie fishing hooks easy, the "Tie-fast knot tyer". Then, I got the idea of a "Tie-fast seizing tyer".
I don’t know whether the fishing tool itself, can be used for seizing but I made my own tools…
So depending on the thickness of the threads I use, I modified three useless head paint brushes by trimming them down and creating a channel. See photo.
Every time I need to seize something, I choose the proper modified paintbrush's head and by following the sketches for the use of the "knot tyer" (modified as well), I make loops around the edge of it.
Then, I insert the loop (or single thread) that I want to be seized in the formed channel and carefully remove all the threads (loops and thread to be seized) from the paintbrush's head. See the sketches and the photos of the process.
Finally, I gently pull the two edges of the loops' thread and I have my seizing knot formed.
The seizing knot is slid able, so I move it to its final place, I cut the edges and secure with a drop of glue.
I hope you find my method easier than others.
Thanks
See what I mean.
Thanks
I have always -when building -used a big needle -both for sizing and splicing. As I normally toke three years pr. model, I have never gotten into sophisticated tools. Anyhow I find your method rather goodHi all.
See what I mean.
Thanks
