Le Soleil Royal ZHL Build Log [COMPLETED BUILD]
First step, at last! I noticed that the keel is a little warped. I had to use clamps to hold the two pies together while the joint dries. I will look for a way to get the warp out later. After all, this isn’t Star Trek! View attachment 246197
Looking forward to your build. It’s been a while since I’ve been able to work on mine so watching yours will be great.
Vic,
Make sure you get that warp out and watch out for a potential twist. On my build I had the ribs glued on then the next day I had both a twist AND a bend. On the next build I'll glue the center piece together then wait a full week to make sure the new environment doesn't cause an issue. Good luck with the build. I'm in.
Scott
Vic,
Scott
Welcome aboard, Scott! It has rained a lot here lately. That probably had an effect. It's settled down some now. I have the false keel on a slip now, and any bend is unnoticeable. Thanks for sharing.
Hi Vic. I will follow this one to the "T". The best of the luck with the Frenchman.
For some reason, I love this stage of the build, where you create a skeleton or backbone of the ship. Maybe because once you install all the bulkheads you can visualize the lines, or maybe because this is the most important step for the rest of the assembly? I have no answer, but I learned, that you cannot underestimate the importance and precision of installing the bulheads correctly against the false keel.
You are off to a good start, Vic!
For some reason, I love this stage of the build, where you create a skeleton or backbone of the ship. Maybe because once you install all the bulkheads you can visualize the lines, or maybe because this is the most important step for the rest of the assembly? I have no answer, but I learned, that you cannot underestimate the importance and precision of installing the bulkheads correctly against the false keel.
It was a pleasure to see it coming together. This is the first ship where the decks fit together the first time without a lot of adjustment. Now it's time to fair the front bulkheads and finish gluing them in.
