Great progress, David. You are doing a great job!!Slow but steady progress
Great job David. Your brass/iron work is great and I know how hard it is at that scale.
Thank you,Great job David. Your brass/iron work is great and I know how hard it is at that scale.
I'll have to get on with mine as well. Working on rigging components at the moment.
It's a great kit. My only advice would be to read and re-read the instructions before proceeding. There are spare components in the kit which I did not realise until I had glued two keel sections together, which effected everything else from then on.I'm just starting the same kit. Have enjoyed looking at yours. Very nice work.
Re-read part of the instructions every time I sit down to work on it. Hoping that helps keep me from making real bonehead mistakes.It's a great kit. My only advice would be to read and re-read the instructions before proceeding. There are spare components in the kit which I did not realise until I had glued two keel sections together, which effected everything else from then on.
Slowly this summer making progress. Couldn't figure out how to remove the laser burn marks. I used a pencil with sandpaper to sand them out on the bulkheads.
