Thanks Kurt. Not having so much luck with the ship's wheel but will keep trying....Creative methods to make the stern window frames and glass, well done.
Thanks for your encouragement Jim. Progress is slow and as my first build there are some serious challenges to overcome, but I still enjoy it immensely. Hopefully others can learn from my mistakes and avoid them in their own builds.Very good progress, Ian, and some fine job on the rudder and gudgeons and pintles. Keep those photos coming, please.
Hi Ian,As you can see by the lack of posts, I got bogged down trying to build the ship's wheel. I (wrongly) thought I needed to complete it, mount it and run the steering lines back to the rudder before continuing with anything else. Here is where I got held up...
I planned to cut the wheels out in sections and fit them around the spokes....
After a lot of attempts I realised this was an unsound method and the parts were too small to butt glue and to hold their shape.
I made some good spokes with my cheap Chinese lathe but getting them a standard size was a challenge.
The hub (drum) was fine.
View attachment 272179View attachment 272180
I started making new wheels out of Queensland Maple and might continue with that after I have had a break.
In the meantime I have set about tidying up a lot of half-finished parts of the build. More to come in the next few posts.
Hi Maarten,Hi Ian,
You can make the rims of your steering wheel on the lathe. First create the correct outer diameter. Then from the front side you hollow it out until you have the correct rim thickness. At last you cut it off and you will have a perfect rim in a fraction of the time when you have to do it by hand.
Dear IanFinished off the inside of the transom.
Trust me. Those gun ports do line up, despite what the camera says!
I'm currently working on the caps on the transom.
Thanks ShotaDear Ian
I like to see your work on the model, you have the ability to think outside the box and create creative working methods (the triangle of wood in the space, the use of two prongs to create a deck nail socket and more).
Well done![]()
Well, you were right Maarten,Hi Ian,
