I wouldn't have felt as bad if there had been a snap, but it literally fell apart along the grain line. Fortunately that's a stronger glue bond than end grain. It's fixed and I'm able to work today.This is one sound, which we all hate when we hear it !!!
"Snapp" - immediately you know, that you did something wrong......![]()
This is very enjoyable. the advantage is you can see significant progress very quickly, not to mention it's great fun and nice looking when it's done. Also my wife doesn't complain as much about where a small boat will go.Enjoying watching your progress. I had a good time with this kit as well.
Overall the clinker planking makes it look like a fun little boat to sail. I'm sure that the deformed top plank can be straightened back out with a little moisture and maybe a light touch of heat to further help soften the fibers. Rich (PT-2)As John R said, wet and use some scrap pieces as mold with braces from inside may help get the curve back as it should.
Another thought is use stiffer rib on outside and clamp to it, if the stiff rib holds proper curve.
Wet and dry with high heat in few minutes and it should hold reasonably well.
I have several of these small kits, mostly from Midwest Products. They have discontinued there ship kit line so all are older or used have built kits I find on Evil Bay.
Thanks, I'll give that a try.Overall the clinker planking makes it look like a fun little boat to sail. I'm sure that the deformed top plank can be straightened back out with a little moisture and maybe a light touch of heat to further help soften the fibers. Rich (PT-2)
This looks very well built and in place. Rich (PT-2)I've made great progress. The dagger board case is in. The bottom frames, quarter knees, inwales and thwart frames are all complete. I've also cut down and shaped the transom. It's taken a few days, but to be honest, I spent most of the time waiting for glue to dry. Overall, I'm fairly pleased.
Rather than post individual photos, I'll just post this latest one with everything in place.
