Hallo Stuglo, accurate, precise description, absolutely beautiful model.
AliExpress. First time use. The progressive "head" ( 1 of 3) took my eye and works well. Need more experience for the peg set upI like your bending machine very much
we can read XF-Model printed on the tool? From where is it?
How is your experience with this tool?
I have a mind to make one of those from scratch. Looks simple enough.AliExpress. First time use. The progressive "head" ( 1 of 3) took my eye and works well. Need more experience for the peg set up
looks wonderful great progress![]()
wonderful work, my dear friendAnother choice or crossroad.
To fit the strakes below the Wales or not?
The port side will be left “free” or open, but as displayed, will not be seen.
Therefore:
The Sheer Strake, #29.
This is an interesting variety, as the standard width expands over those ports where the neighbouring strake would have to be narrower than 2.65mm when fitted above those ports.
This is called “working down”. A sort of flap.
The ports where this happen are shown(1,2,7,8), but they did not exactly match mine(1,2,6,7). (But the effect over port 1,shown on p23, is absent on p15!)
The strake is 1.6 thick.and when not worked down.5.5mm wide.
Positions of the butt joints are given (Kaft, Baft,6fore and 14fore)
Note hook scarf joint between 2nd and 3rd part.
The line runs almost parallel to Wales but not exactly. It is very important because it determines the upper line and “shape” of the ship.
I took an overly wide blank strip, marked the position of ports with spare 5mm either side. The interval narrowed to required, off the model, the part glued into position. When dry, the extra width is removed until it is in line with the upper edge of the port.Then an angle appropriate to the remaining extra width, is made.(chisel).
The gap between the Black strake and the Sheer strake, is filled with strakes #24-#28 (called the Stuff of the Topside)
This gap is measured at various stations and divided by 5- to give an average plank width.
The lowest strake is 1.9 thick and the upper is 1.06mm, and between the others are tapered-
EXCEPT the bow section (foreward of the 1st port)all will be 1.6mm, matching the Black strake and Wales.
The strake #25, is also worked as required by the previous rules. I failed to realize this until all finished (including treenails) , tried a repair by changing just the areas under the ports, saw it was a mess, and removed and remade the whole strake.
Note that when made, the worked-down is 1.6mm thick. This has to be sanded to blend with the neighboring strakes 1.06mm.
I helped the tapering by using 1.6mm stock for strakes #26 and #27.
I tapered with some newly acquired sanding sticks. They work very well and are ideal in size and shape (80-400)
View attachment 277615View attachment 277616View attachment 277617View attachment 277618View attachment 277619View attachment 277620View attachment 277621View attachment 277622View attachment 277623View attachment 277624
