Thanks Daniel I'm enjoying this build more than I thought I would and beginning to wonder why it's taken so long to restart this kit.Nice clean tight work as usual Tony.
Thanks Grant and welcome to my log. I have seen your Victory build, excellent work a very big undertaking for a first kit. The Victory is a ship I would like to build but it's likely to be the last one I make.Tony she is just superb. Awesome
Thanks Daniel one of the things I was planning to do with this build is to copper the hull. Although it's not necessary with this kit I want the experience for future builds. Your log has provided lots of information on how to tackle this job.
Tony
Good morning Tony - good thinkingThanks Grant and welcome to my log. I have seen your Victory build, excellent work a very big undertaking for a first kit. The Victory is a ship I would like to build but it's likely to be the last one I make.
My goodness Tony! You are Mcguyver, Inspector Gadget, Superman, Shaft and James Conn all rolled into one!! I just love how you make equipment out of spare parts that are lying around. I can't wait to see your rope.Having seen the rope made by Paul and Daniel (Vasa builds) got me thinking about what rope to use on my Unicorn. I have already used some of the Corel rope on the Black Pearl and didn't like it very much.
I had most of the parts for a rope walk already made it just needed putting together.
This is what it looks like, everything is recycled/reused from surplus parts. The aluminium extrusion was originally part of a conveyer system, it's 3 metres long. I have 3 other pieces which I could join together if I needed to make some really long rope.
There are 6 hooks around the outside and one in the middle they are connected by gears and driven by a motor. The hooks are setup so I can make 3 or 4 stranded rope.
At the other end the hook is connected to a flywheel which can freewheel or be powered by an electric motor. I will use a scale to check the tension.
Because of the long length of the rope walk I made up a set of pulleys to apply the tension to the rope.
All the carriages run on small bearings inside the slot.
Now for the fun part start making some rope. I've got some overlocker thread not the best but it's cheap (I expect most will end up in the bin). I'll try it out tomorrow and see what happens.
Thanks Daniel that's a huge complement. If there was more stuff available back then I would most probably have bought one. I have made some ropes but I'm having a bit of trouble getting a good photo, will post later.Cool. If you have not seen this video it is worth watching...
The side rails and scrolls have been troublesome for a few reasons, this is how Corel intended them to be done.
The scrolls are made from 6mm dowels blended into the rails. I tried this with some scrap pieces and was not happy with it. The other problem I had was there was only just enough material if I didn't get it right the first time. I would have to order more.
This is how I ended up doing the rails, simple alternative but it looks better than my trail run.
I had difficulties keeping the forward rails in place while gluing so I made some wooden pins to hold them in place. I only needed a couple but looked better with more.
Job done.
Hope everyone has a merry Christmas and a safe happy new year.
I LOVE the rails you made. You've got mad woodworking skills Tony! Precision for days...
The rails are a great addition to what is turning into a beautiful ship!
Thanks for the kind words. The curves weren't that hard to do, my main concern was not having enough timber to complete the job.Very, very well done. The curve isn't easy and you got it. Plus those wood pins excelente job !!!!
Daniel
Hi Daniel I'm not to worried about it as there is not much I can do to fix it. After a quick check it appears the port side upper deck is too high. As the deck was nailed down firmly maybe it's an issue with the frames. Something to watch out for on my next builds.Counting the planked strips, they are the same at both sides. Could it be with the deck positioning ? That can't be seen from the pictures.
Nevertheless, it is looking very well and that issue is difficult to see.
Great Job !!!
Daniel
