Here is the tool you are looking for (I think). It is made by Amati. However, it may damage your plane's blade as the tool has an aluminum top.
View attachment 287227 View attachment 287228
I use this tool, bought it a long time ago on AliEpress. You can make the similar one. Technically speaking, a simple board and two parallel planks should do it.
View attachment 287229 View attachment 287230
Thank you for your suggestion. JackI don't have any fancy tools, so planks are tapered using a cheap metal vise and razor knife or sanding block. The strip is clamped in place at the desired angle after marking a line on it with a pencil and sanded down to the level of the vice or to the pencil mark. I'm not worried about sanding marks on the vice jaws because the vice only cost $10.00. Besides, it stays rust free this way!
A great idea. Thank you. JackFinally facing the scary task of planking the hull. In my research I saw someone using two metal (?) pieces to hold the planks while planning. Where can I find or make such a tool? can’t tell you how nice it is to have help. Jack
i used 2 pieces of flat stock from the local hardware store and either a vice or clamps to hold the metal tight together
post#75 on page 4
Royal James sloop
The problem is fixed by "cutting" the garboard plank to fit the hull. lets take a look at how the shipwright solved the problem a look at a hull you can see at the stern the garboard and bottom planks flare out the bottom yellow arrow is the lower edge of the garboard against the keel and the...shipsofscale.com
My preferred bending method is soak them then clamp into position on the hull to set dry. The plank has then taken all the bends and twists.That looks like the tool I've just bought. I tried to buy the plane but couldn't find one in stock. I decided that the vice would do and that I could do what I've done so far: craft knife, files and sandpaper/ sanding block. Time will tell if I'm right. I was thinking of your same problem. My other problem was bending the planks. I haven't made up my mind how to do that, yet.
I think I will try your method. Thanks . JackI use the sandpaper method. 1. pencil line on planking, 2. I use a sears 4x36 sander and sand to the line 3. adjust the sandpaper grit to obtain the proper edge.
Jim, Itried to find the Amati tool shown above with no luck. Any ideas of where at I can look? JackI use the Amati version, the all aluminum one noted above. I clamp the plank firmly and just use a sharp no. 11 blade to slice down the plank. I found using the blade works quicker and cleaner than a plane. I have found the Amati tool quick, easy, and accurate.
Good suggestion. I bought that plank holder a while back and I've used it more as an vice and all purpose holding tool than for its originally intended purpose.Take the metal strips off and replace with hardwood and you will have a good jig or better yet copy the whole thing out of hard wood.
Good question. I did not find it initially searching for Amati. What I did find was the Mantua version in Cornwall Models in the UK (shipping is easy} (Mantua Strip Clamp - 8155). I also found the Mantua version on Amazon. Mantua Model 8155 Strip Clamp and Hull Vise for Ship Model Building My thinking is that it is not an Amati tool but rather from Mantua. Now, I said to self...get my clamp down from the shelf and see who made it...mine is from Panart (Italy) with the same number, 8155. So go figure...and I don't remember where I got the Panart version...it has been too long ago now.Jim, Itried to find the Amati tool shown above with no luck. Any ideas of where at I can look? Jack
