**VIEW THREAD HERE** |
I am seriously considering using Maple for small pieces and detail instead of the supplied Basswood. It is a very hard, durable wood with a tight grain. The drawback of it is when it comes to staining.Hi all
Have anyone used Hard Maple for frames/keel/stem and stern post construction ?
Thank you !!
Daniel
Daniel,
if the the woodgrain is not too coarse, I cannot see why you couldn't use it. I am sure Dave Stevens will chime in with his expertise.
It is a dense wood with a very tight grain. It absorbs stains very slowly, requiring often several coats. Note: it can also result in a splotchy and may require a pre-stain conditioner. And you may considrr a wood dye instead of staining.Why staining is a problem ?
This is a good tip I will test in a scrap piece tomorrow.
Thanks
Daniel
That wood would look great with a clear varnish on it, or a tung oil finish.
Great idea!I will try to do a test on a piece and will report back.
Nevertheless, I am itching to know, why have not been used on frames, keel, etc. Most modelers use it for deck planking or small pieces, like my gratings.
I am itching now to test the stains tomorrow.
Thanks!!
Daniel
Hard Maple | The Wood Database (Hardwood)
www.wood-database.com
Nevertheless, why I don't see POF ships done with Maple.... what am I missing here ?
Nevertheless, I would like to hear if someone have used Maple to built frames, keel, etc, instead of Cherry, Pear or Boxwood.
i used Maple to frame the Tecumseth,
Harold Hahn used Maple to build the ships in his colonial shipyard diorama. I sell a lot of timbering sets in Maple.
An interesting bit of information is forums like this are only a small fraction of model ship being built so you are not really seeing the whole picture.
here is a Confederacy frames with Maple
Confederacy 1776 (Maple Timberset by Lumberyard)
Hallo everybody, This model of the USS Confederacy in style of an admiralty models and is was built in 5 Years. The guns and fittings are handmade of brass, the frames are maple wood, the planks are Swiss pear, cherry and ebony wood. The steering wheel is fully operating. If you turn it, the...shipsofscale.com
there is
Hard Maple
Sugar Maple
Soft Maple
Spalted Mape
Red Maple
Silver Maple
and these are just a few out of 200 types of Maple
