Szkutnik - New Design POB HULL - New solution for impatient modelers
Ahoy!
Sailor_ed wrote: Have you developer Any plans for smaller vessels that could be resin pronted?
Sailor_ed - what kind of small ships interest you? We design and we perform hulls of models on private orders.
From small sailing ships, currennly I can recommend hulls for models: La SAVOIE and LA VOLAGE.
View attachment 295503View attachment 295504
In this year will be available also the hull to the model LA MAHONESA (Works in progress).
Due to many questions about the price....
PRICES:
LA SAVOIE - Hull in scale 1/72 ( length 39 cm) – 100 Euro
- Hull in scale 1/36 ( length 78 cm) – 170 Euro
LA VOLAGE - Hull in scale 1/72 – 100 Euro
Hull in scale 1/48 – 150 Euro
Hull in scale 1/24 – 200 Euro
HULLS IN OTHER SCALES ARE ALSO AVAILABLE :D
PRICES OF GREATER HULLS (3D PRINT)
El casco de longitud: 70-100 cm - el costo es de 300 a 500 euros
El casco de longitud 100 - 130 cm - el costo es de 500 a 800 euros
En la compra del casco y la decoración al modelo (juntos) hacemos el descuento. :Rodar los ojos:
Ahora tenemos cascos listos diseñados para modelos:
Veleros: Saint Philippe, HMS Tiger, La Volage, La Savoie, El barco de 74 cañones, Le Commerce de Marseille.
Buques: Wilhelm Gustloff, Bismarck, Iowa, Yamato/Musashi, Scharnhorst, Akizuki, destructor Fletcher, destructor Hunt II, buques de transporte americano tipo: Victory, Liberty y petrolero T2.
Hola. Saludos desde Valencia. España. Podrías dar los precios de las tallas de proa y popa E:1/24 de La volage(Ancre) gracias por tu ayuda
Hello, Greetings from Valencia. Spain. Could you give the prices of the bow and stern sizes E:1/24 of La volage(Ancre) thanks for your help.
Ahoy!
@Luango bow and stern part of hull....... you mean the two halves of the hull? (bow + stern = full hull) or You will build the bow and stern of LA VOLAGE separately?
Decors for LA VOLAGE are also available pearwood or 3D Print
Ahoy!
3D PRINT HULL (PLA) for model LE COMMERCE DE MARSEILLE in scale 1/72. Hull in other scales is also available :D
3D PRINT HULL "LE COMMERCE DE MARSEILLE" compared with the Heller's model HMS "VICTORY" in scale 1/100.
Ahoy!
Our member @WojtasS just started his building log using this hull
Ahoj!
@Bryian - "LE COMMERCE DE MARSEILLE" in 1/64 scale ? YES WE CAN DO IT. Hull length 1037 mm Width 243 mm.
We can make hulls using this method up to hull width 300 mm.
Wider hulls - we will additionally divide the hull into left and right parts. ROTF
WE CAN DESIGN AND PERFORM EACH HULL ON A PRIVATE ORDER. WE ARE WAITING FOR PROPOSAL.
Very interesting project. Would you be interested in cooperation?
Could I produce for this model the laser cut decks that we produce for other models? We have for it a special veneer. Also brass gun barrels, or a set of CNC walnut blocks?
Thanks for the reply and fingers crossed for more interesting models.
Super project! Only here is a question for the authors of the La Vollage monograph: how did the sailors climb onto the forecastle without a ladder? Jumped with a run or used a capstan bar for a push ? This is probably how the game of golf pole vault was invented.
