HI KRIS DID YOU GET MY EMAIL HOW IS THE PROJECT THAT WE DISCUSSED ALSO IF YOU GET A CHANCE LOOK AT MY HARBOR DREDGE LOG AND SEE IF I AM ON THE RIGHT TRACK WITH THE WHEEL SUPPORTS, THANKS. GOD BLESS STAY SAFE YOU AND YOURS DON
Hallo @LuangoHola. Saludos desde Valencia. España. Podrías dar los precios de las tallas de proa y popa E:1/24 de La volage(Ancre) gracias por tu ayuda
Hello, Greetings from Valencia. Spain. Could you give the prices of the bow and stern sizes E:1/24 of La volage(Ancre) thanks for your help.
Estoy empezando aHola [USUARIO=15805]@Luango[/USUARIO]
te deseamos lo MEJOR y un FELIZ CUMPLEAÑOS
Pastel de cumpleaños
Por cierto: ¿Ya comenzaron los trabajos en La Volage?
GRACIAS¡Feliz cumpleaños! Pastel de cumpleaños
GRACIAS¡¡Feliz cumpleaños!!
GraciasFeliz cumpleaños
Saludos Mirek
GRACIASfeliz cumpleaños LuangoPastel de cumpleaños
Hi! This is a 2-side machining, I assume, you machine one side first, than manually flip the part and mill the other side, the same way as I usually do too. What do you use for alignment during flipping? I use drill bitts 1.5mm in diameter and they are ok when the blank thickness is less than maybe 12-15mm. But in this case the thickness of the blank is big, maybe 50-70mm. So the mill bitt diameter will be big and I am wondering what should I use.. some kind of the pins?..Ahoy!
Guys - Thank you for your interest in the subject of the hull. There are many connection methods. We will try to test a few and choose the optimal variant.
Currently we have moldings with hull elements only.
Hola, saludos desde Valencia. España. Podrías dar los precios de las medidas de proa y popa E:1/24 de La volage(Ancre) gracias por tu ayuda.
