Model VICTORY by Deagostini, scale 1/84 [COMPLETED BUILD]
It looks like I missed one point and did not show it to you, dear colleagues. When I was making the tops, the masts were made at the same time. Now I am installing the yokes and on top of them the front fish. The front fish was installed on the fore and main masts, there was no front fish on the mizzen mast. I read back in Nelson's Anatomy of Ships that during the construction of the ship there were woolings on the masts, but by the time of the Battle of Trafalgar they had been replaced with iron yokes. The yokes are made of brass strips 0.2 mm thick, 0.8 mm wide and blackened. The result of the work on the photo. If you have any questions, I'll be happy to answer.
20220422_151028.jpg20220422_151054.jpg20220423_165028.jpg20220423_165012.jpg20220423_165136.jpg
The yellow color appears too bright. I think the HMS victory color is more tan and should be as below:
Kurt, hello. Over time, it will rub off and be dirty yellow. And about the colors on the ship museum in Portsmund, I talked with one of the people who worked in this museum. He says that the current color on Victory has nothing to do with the present. In addition, my masts fit into the general background of the ship with its yellow sides.
View attachment 304965View attachment 304966View attachment 304967View attachment 304968View attachment 304969
Immaculate modeling, kudos!
Hi Sasha!
Very clean work on the Victory. I am always interested in the how the materials are processed. What kind of glue did you use to glue the tapes to the mast, how did you prevent the glue from oozing out and smearing?
Best regards
Thomas
Hello Thomas.
Glue for yokes used like this. This is cyanoacrylate glue, but in the form of a gel. I applied it with a needle, in a very thin layer.97f214742be4fcd2c9981967c7ee4944.jpg
Ahh Kurt the Victory color debate....hours of articles here and still continued dispute... I went for pinky color ( as in photo above ) but is fading into a fleshy color. Eish. Even the academics can’t decide on which color reflects the Victory at which time. I guess that gives us freedom to choose which ever ;)....just not greenROTF.
BTW Sasha brilliant detail on the bowsprit and masts. Cheers Grant
Thanks Grant
I did not know there was a debate. I thought they found some paint samples in the wood and figured out what the most correct color was.
Good morning Kurt. Yes Crick Smith (think it correct name - memory not so good anymore ;) ) from the Lincoln university did using a new technique and paint sampling technology. A paper was presented and used for the repainting of the Portsmouth Victory. This was officially “adopted “ by the National Museum of the Royal Navy and hence the new pink/yellow ochre (mix) color paint work. There are however many academics and others who have disputed his work....does leave it open for choice- Model paint for this from different companies e.g. Admiralty paints vs Vallejo for the Victory all come out slightly different. I think Admiralty is the closest if you can get it. There was also a time when she was painted black and white - pre Trafalgar.
Cheers Grant
Very nice indeed Sasha, an education in motion Thumbsup
- Mark
Good day everyone. Started lining the bottom. There was a problem with the copper plates, so the plating will be brass. This is not prohibited by the rules of the competition.
And so, from the beginning, I marked out the top line along which the skin will go. On Victory, the top 12 rows are different from the bottom. The laying scheme was a little earlier in post No. 268. So far I have laid 150 sheets. Spent about 7 hours on this. I assume that there will be approximately 2,000 sheets. Of course, I will not lay out each row, but I will show the main stages. So don't lose me ;) 20220428_154524.jpg20220428_154540.jpg20220428_171620.jpg20220429_185516.jpg20220429_185524.jpgIMG-20220429-WA0007.jpeg
appr. 20 sheets per hour - not so bad speed -> you will see, that with the time it will go faster
Which type of "plates" or producer are you using? Because we can see, that the show already the nails so I guess they are prefabricated.....
How are they fixed to the hull - with CA-glue like in your post #290?
Sasha I can only repeat what others have said before, your work is excellent.
I am curious, is it copper or brass sheathing that is not permitted in competition? The company I used to work for was involved in the restoration of Cutty Sark.The hull is plated with Muntz metal which to look at, looks little different from Brass.
Kind Regards
Nigel
Uvek, these are ready-made plates from the Russian company Microdesign. They are cut to size and have imitation rivets on them.
