H is probably sleeping and doesn’t know what’s happening to his build log
I won't say anything on symmetry...
Rog, please tell your grandson I still have to do the sanding!Not so sure Paul, my young grandson took one look and said “why is he making Groot?” - ok, Heinrich, Google time again
I am with you on this one Paul - there is a definite resemblance and even more so now that I have cut off the excess planking.
Thank goodness, it’s his bedtime soonRog, please tell your grandson I still have to do the sanding!![]()
H SHOULD have been sleeping but was busy trimming off the excess planking. The admiral was working last night so she couldn't come home - when I am on vacation and I am on my own, I can be very irresponsible sometimes when it comes to bedtime!H is probably sleeping and doesn’t know what’s happening to his build log
Never in my life will I ban my two artistic directors - their creativity has just reached previously unheard-of levels! That makes for exciting times ahead!And when he awakens Paul and I will get banned![]()
Please, you're just asking for it!And when he awakens Paul and I will get banned![]()
Thank you very much my friend. With me also replacing the lower part of the transom planking, I paid a lot more attention to wood grain with the result that the oak now has a much more uniform look to it. Everything seems to be working out now - almost there but just not yet (now busy lining the ports).Good recovery Heinrich! A much better result the second time! Looking forward to seeing more of this ship!![]()
Nice recovery with the gun ports, my ship went through the same procedure to get them all lined up.Well today I think I should rename Lincoln Shipyard to something like "The Butchery".
This morning I started by soaking the part on which the operation was to be performed in hot water - directly against my own advice to @Nomad Mark. The reason I did this was only because this is a @Kolderstok kit and because I have implicit faith in the quality of the materials. Thereafter it was a case of painstakingly wedging the Xacto blade between the transom and the planking and leveraging it in further and further, until it wouldn't go any further. More soaking in hot water and onwards. Eventually ...
Now I could clearly see just what a mess I have made of this part.
Scrap wood was then sawed to fit into the openings and glued in place.
And then I changed tack. Instead of immediately planking the transom, which would then mean an exact repeat of my initial attempt, I decided to first cut out the ports in the transom. Some wise man once said that the definition of insanity is to repeat the same thing twice and then to expect a different outcome.
Here is my transom doing its best impersonation of the evil "Falconetti" from Rich Man, Poor Man. Oh and by the way, if you think you are seeing a different wooden plug on the right to the one, I have shown you before, you are right. I messed that up too and had to replug it. @rtibbs Ron, have you got special coins for Do-Overs while you are doing a Do-Over?
Both ports cut-out. You need to squint your eyes and focus only on the light shining through, otherwise it will still look like the dog's breakfast. I have cut them out inside the lines to allow for some fine-tuning once the cut-outs are finished. The idea is obviously that I will now drill my pilot holes from the back of the transom and score the wood as far as I can before flipping it over to do the final cutting.
And planked. As you can see, I haven't done any sanding or finishing to the planking. I didn't use any clamps this time so now the glue just has to dry properly until tomorrow morning before I will make attempt #2.
Thank you very much Richie. I really do not know why I made so much unnecessary work for myself. Be that as it may, it now looks like it should!Nice recovery with the gun ports, my ship went through the same procedure to get them all lined up.
Groot is a legend- one of my favorite Marvel characters.....Not so sure Paul, my young grandson took one look and said “why is he making Groot?” - ok, Heinrich, Google time again
