Lookin’ good Jan !!
Whew, I guess the whole country is getting Florida weather lately.
That’s ok though. We’ll share if you promise to take some of the hurricanes also
Yup you are absolutely right, a great spot for a pin. I had pinned the 1st 6mm plank there initially. I also pinned #2 and #3 planks, I noticed a problem while trimming and sanding the ends of all three planks. The 1st plank's upper edge was glued in tight but the bottom edge of the plank was not. I did the H2O trick to loosen the PVA, let the area dry, gently removed the glue residue from the three planks and stern, applied glue to the planks edges and used the force of the rubber band to hold everything in place.
