- Oct 25, 2022
Hi to all and welcome to my first build log.
So, in case you are wondering why on earth would I want to choose this as a first build of a wooden ship? Simple answer is because I love large models and this has been on my bucket list for a number of years and a few months ago I got the chance to acquire this beautiful kit. Also, I have over time, acquired various tools which should aid me in making a halfway decent job of this kit.
I have reference material and I have various things to help me, I have already made up a few one time use jigs for cutting planks for the decks and jigs to taper the masts and yards with.
I'll be honest here, I have already been at this kit for a couple of months, I have the 18 bulkheads glued to the false keel and that took two weeks of fettling and filing to get them to fit.
I have the lower false gun deck not yet glued
Lower gun port blanks are glued in upper gun port blanks not yet glued in because I need the false deck here to be a removable item while I plank it. As it stands here the framework of the ship is straight and true to within 1mm.
The bulkheads, the false keel, the dummy barrel strips and the false lower gun deck are all in CNC cut 5mm ply. As it stands it is currently just shy of 36 inches long!
I am currently at a stage where I am planking the false lower gun deck. The actual manuals only calls for this to be done where visible from the other decks but I am doing the whole deck.
The planks are Tanganyka strips (as supplied in the kit) 4mm x 1mm and cut to 85mm long. im staining each plank with a stain called Georgian Medium Oak.
My centre plank, or king plank is 6mm wide. Ive used this width because of the false keel's 5mm width and to allow the 4mm strips to run either side of this keel as som of it protrudes through this false deck.
I laid the 6mm centre plank against a steel rule clamped in place and then after that dried and the rule was removed I ran parallel lines of black thread either side of this plank for caulking. I am currently still adapting the technique of laying my planks and caulking with black thread, and so it is still not a fully developed technique but it does seem to be working for me.
Anyway that is a brief summary of where I am with this build and so I try to keep this up to date as I didn't intend to put this on a forum but now I have.
I have missed out loads already that I have done but there is so much more to come and hopefully I can build this.
Thanks for now
Cheers
Thanks for now
Cheers
