HMS Medea (28) (1778) 1/48 scratch build
think I'm making some progress with my rope walk.
I think so, Ian. Don't want to add trouble to your project, but I would like to suggest a polyester thread. I looked at your images and can see the fuzz, once you will use it on the model, it will attract the dust.
Thanks Jim
Yes, the last image is polyester - Guterman 100% polyester - but I didn't run a flame along it when finished. I noticed Ohla did that to take off the fuzz. I need a lot more practice yet.
Thanks Jim
Very good, Ian. No need to run the flame (until you grasp this technique), you can run thread against beeswax brick, it will do it!
Ian, in my thread you can read that I put polyester in the oven.
And another tip I can give you is to use Serafil from Amann. 120/2 give a very realistic result of scale rope with no fuzz. The problem is with the yarn you use is, when you look close it looks like cable.
Here you see the difference of real rope and cable
Rope
Cable
Slowly, slowly...I've spent the last few days making the twin capstans.
I made the gundeck one first to learn how to do it. It will be hidden from view eventually.
Then I made the Quarterdeck one, with more detail. All dry fitted so not aligned very well yet.
To finish it off I added 5 chains and pins to lock the capstan bars in place. Very fiddly but I'm learning all the time.
Now I see the photos, those pins look ugly. I'll straighten them a bit more and black them before installing.
Over the weekend I will finish it all off, paint it and install. One more step towards getting that elusive quarterdeck planking on :cool:
Painting isn't my forte but here goes.
Sharp eyes will notice my big mistake many months ago when I laid the gundeck planks and gratings. The first grating I did is in the wrong place, but since I already have the quarterdeck beams all placed in the correct position I've decided to mount the gundeck capstan on the grating instead of in front of it. Although I know I could have removed the beams, cut out the grating and made a new one, I want to get on with the build. I can live with it once the quarterdeck decking goes on.
There is camera distortion in this last image but I just want to show off the brass work ;) Brass is my favourite material to work with, but a brass ship would be too expensive to build. :cool:
The capstan bars will never be in use (this will be a ship at sea) so they will be stored below the quarterdeck.
Next to continue with the wheels and the binnacle.
Maybe you can lay some "boards" (made out of veneer) on top of the grating (only in the length of the grating) - it will be less visible
Here you go Uwe. All fixed (without removing any beams).
I see it's not quite flat so will adjust it before I glue it in. Thanks for encouraging me to fix it. I can be lazy sometimes. :cool:
Much much better - and technically correct (by the view)
If you would not have done something now, you would look at this dteail for the next 20 years and think by yourself why you did not change it in time
Very good
The next item of deck furniture is the binnacle. I started off with some basics.
From the start I intended this to be as realistic as possible, including a 3mm LED 'lantern' and actual chimney.
The compasses were made with small dowel and the rounded tops of brass-plated paper clips. A small compass dial was drawn on cardboard and inserted.
More to come...
So after breaking or rejecting 6 attempts to make a satisfactory double ship's wheel I think I've got it at last.....
Following the images by Lucius (Rüdiger) https://shipsofscale.com/sosforums/threads/hms-euryalus-1803-scale-1-48-completed-build.8335/page-16 I finally settled on what is probably the most difficult method but which helps to prevent the rims breaking when being drilled.
I can't hope to ever reach Rüdiger's skill level but his workmanship gives me ideas which I can practice with.
The main barrel was done on the large lathe at our community workshop. Not ideal but I managed.
The 1.5 mm holes for the spokes were drilled out with my Dremel drill stand and I must say it was as steady as a rock.
The spokes were turned on my small bead lathe.
Dry fitted for sizing against the plans.
Spokes glued up.
The delicate job of cutting the wheels and drum free.
Still plenty of cleaning up to do but I'm satisfied with the result after so many failed attempts. :cool:
Happy New Year to all on SOS and may peace break out around the globe in 2023.
View attachment 348434View attachment 348435
Spokes glued up.
View attachment 348442View attachment 348446
Wow, wonderful work :D OkayExclamation-Mark
