I think so, Ian. Don't want to add trouble to your project, but I would like to suggest a polyester thread. I looked at your images and can see the fuzz, once you will use it on the model, it will attract the dust.think I'm making some progress with my rope walk.
Thanks JimI think so, Ian. Don't want to add trouble to your project, but I would like to suggest a polyester thread. I looked at your images and can see the fuzz, once you will use it on the model, it will attract the dust.
Very good, Ian. No need to run the flame (until you grasp this technique), you can run thread against beeswax brick, it will do it!Thanks Jim
Yes, the last image is polyester - Guterman 100% polyester - but I didn't run a flame along it when finished. I noticed Ohla did that to take off the fuzz. I need a lot more practice yet.
Thanks UweMaybe you can lay some "boards" (made out of veneer) on top of the grating (only in the length of the grating) - it will be less visible
Here you go Uwe. All fixed (without removing any beams).Maybe you can lay some "boards" (made out of veneer) on top of the grating (only in the length of the grating) - it will be less visible
Thanks Bryian. And thanks for all the likes. It gives me encouragement to keep trying.great stuff Ian.![]()
Thank you Shota and the same in return.Ian my friend
Merry Christmas and Happy Holidays for you and your lovely family![]()
Wow, wonderful workSo after breaking or rejecting 6 attempts to make a satisfactory double ship's wheel I think I've got it at last.....
Following the images by Lucius (Rüdiger) https://shipsofscale.com/sosforums/threads/hms-euryalus-1803-scale-1-48-completed-build.8335/page-16 I finally settled on what is probably the most difficult method but which helps to prevent the rims breaking when being drilled.
I can't hope to ever reach Rüdiger's skill level but his workmanship gives me ideas which I can practice with.
View attachment 348434View attachment 348435
The main barrel was done on the large lathe at our community workshop. Not ideal but I managed.
The 1.5 mm holes for the spokes were drilled out with my Dremel drill stand and I must say it was as steady as a rock.
The spokes were turned on my small bead lathe.
Dry fitted for sizing against the plans.
Spokes glued up.
The delicate job of cutting the wheels and drum free.
View attachment 348442View attachment 348446
Still plenty of cleaning up to do but I'm satisfied with the result after so many failed attempts.
Happy New Year to all on SOS and may peace break out around the globe in 2023.
