Launch of the ship "Twelve Apostles" in 1:48, Master Korabel [COMPLETED BUILD]
Moscow, Russia
I'm starting a new project, it's a brand new kit by Master Korabel, released in December.
These boats were part of the equipment for all the 1st rate ships of the Russian Navy in 19th century, not only the “Twelve Apostles”. Launches like this were used for patrols during the defence of Sevastopol in the Crimean war (1854-55) after the sinking of the Black Sea fleet.
The kit allows you to build the launch in different versions – with or without rigging, with oars or under sails, armed for a landing operation or for an expedition, and so on.
My kit is an extended one, all in pearwood and with ready-made sails.
For framework assembling this kit provides a 3D plastic jig, instead of a wooden holding frame. As you can see, the model correctly copies the real boat's construction.
The carronade is metal-cast.
The sails (only the reef points are missing).
25 pages of various schemes and specifications.
To be continued (after the start).
Good morning Vladimir. That looks like an amazing kit. So much detail and documentation included. I will pull up a chair here. Cheers Grant
Going on with the frames. The process is quite fast and easy, only the bow frames need some special attention.
I forgot to install the transom on the keel before glueing the frames, but fortunately it's not a critical mistake.
I liked the new approach to the construction of the ship which is expressed mainly in the jig/plastic mold which supports and enables optimal accuracy.
I will continue to follow with great curiosity
Good morning Vladimir. That plastic jig is so clever- it makes a difficult process easier. I wonder why all POF manufacturers don’t use it? It’s like every frame should be just perfect. Nice. Cheers Grant
1) Here in Russia it's a patented technology and 2) it requires another technological process and more expenses for the manufacturer.
Do you know more high quality Russian ship kits manufacturer? I am building a few Master Korabel Brigantina Phoenix ships and I am very happy with the quality.
