This is very educational, Paul. Men doing this in the real world, back in the day.... mind blowing!
But they just didn't use such large sheets of glassThis is very educational, Paul. Men doing this in the real world, back in the day.... mind blowing!
As always, I am grateful for your guidance Christian.Paul,
my experience with double sided tape is not as good as with rubber cement (for example Marabu Fixogum). The adhesive of the tape is mostly to strong, and is not as easy to remove it from the frames.
Make yourself two copies of the DoF Plan and give each frames a number. Now you can mark each frame which you have prepared at the plan and write the number with a pencil on the frame. (I use the number of the station lines followed by a small a (after) or f (fore) for this task). I doN't know if the kit uses a jig. If not I can only recommend to prepare one.
Your proces is lookinge very well structured. I wish you a lot of meditative hours building all the frames of the sloop.
The frame design is in this detail simplified (what is for the scale of your model absolut fine). At the original ship it's more complicated, but you can show this only at 1/36 or another bigger scale.
There are two fully shifted timbers also in the original drawing of Cygnet. They are build wrong at the beautyful model Dean shared with us. The thickness of the futtocks is given by the dimenison. The problem at this model is that the chocks are not build correctly. The width of the chock has to be the whole with of both frames.
Just catching up Paul. Again, your work reaches a standard I will not realize for some time, if ever. I too think better in metric terms. As an American, I cannot come to understand just why. My best friend is a retired machinist, who owned his own company. When I relate to him what I've done on my ship and express it in metric terms, he immediately converts it into imperial decimal terms. He is a walking, talking conversion table. Now if I could get him to sit next to me on my work bench.....alas. To add to the conversion complexity, the current monograph I'm using is in real imperial terms, but using the French foot, which is not 12 in/ft.Thank you kindly, gentlemen, for the encouraging posts and likes. I've decided to refine the tapering a bit more in order to get me closer to the build requirements found in TFFM.
A passing observation from my experience using this series of books thus far: the measurements provided in the text are generally given full-size and in the imperial system. For example, for the stern deadwood I am told to make the width at the bearding line (basically where you see the notched area for the frames to seat into) 15 inches and then taper down to 5 inches at the bottom where the deadwood joins the keel.
By using actual measurements from a full-sized ship this allows the book series to accommodate every modeler's preferred scale. Makes perfect sense, right?
Well, this creates all sorts of tripping-up points for me because I think in metric (Why, you ask? Because I can picture 2.6 mm in my mind but not .104 inches). This means I need to first convert inches into mm and then adjust for my scale (1:48). Of course, the math isn't hard, but it all introduces room for mistakes to be made. I find myself constantly checking and recalculating things over and over again. I can't tell you how many times I've said to myself: how can you be so dumb?
When my dad was frustrated with me he used to say, "you've the dumbest smart kid I ever met." I didn't like that very much - but it seems he may have been right.
As I'm posting as I read, I'm not sure if anyone has suggested this or not, yet. Is there a way for you to prepare the wing transom and dry fit to give you a better visual as to how the transition from stern post to wing transom will look/happen, assuming the wing transom will also have a rabbit where the planks transition from the stern post to transom? Sorry for the long sentence. I may have to download that app, Grammarly(sp).Work continues on the aft centerline...
The precision required is beginning to concern me. I have been having a hard time committing to the work out of concern that I'm messing something up now that won't be easy to fix later. I find myself thinking: I guess that's right more often than I would prefer...
It seemed best to only partially finish the rabbet at the upper sternpost at this stage. I assume I will be able to refine it later when the transom pieces are fabricated and test-fitted.
I'll say this much: POF construction is quite a challenge in terms of figuring out WHAT to do - as well as the actual DOING. I have a deeper respect (awe) for some of the work I see on this forum than I had before beginning this build.
Some double sided tape is made specifically for wood working. It is "low tack" and leaves no residue on the wood, while maintaining a very good temporary adhesion. I found such tape on Amazon.Paul,
Yes, this is exactly what I will do. Thank you.As I'm posting as I read, I'm not sure if anyone has suggested this or not, yet. Is there a way for you to prepare the wing transom and dry fit to give you a better visual as to how the transition from stern post to wing transom will look/happen, assuming the wing transom will also have a rabbit where the planks transition from the stern post to transom? Sorry for the long sentence. I may have to download that app, Grammarly(sp).
Hi Paul, Bob Hunt here. Thought I'd chime in to thank you for the compliment on my kit design. I worked very closely with David Antscherl and Greg Herbert when I designed the kit. I used David's drawings with his permission and also paid him a royalty for every kit I sold. Greg Herbert and I go way back. He provided me with every photo he took when he built the prototype. I attended some special classes with him and David at his house in Maryland and took my prototype model for the class attendees to see.This piece (stern deadwood) was almost the end of me: tapered top to bottom and also front to back - and then notched to receive the aft cant frames. But the kit design made this something even a relative newcomer could accomplish with careful chisel work and sanding blocks. Well done, LSS and Mr. Hunt.
The top to bottom taper should be more concave but I'm hoping this will still work. Thanks for stopping by!
Tobias is correct. I can't recall what my reasoning was for the "U" shape of the rabbet at that area, perhaps just a senior moment or brain fart but if you think about it, the planking is coming around the side of the ship so it stands to reason it would fit best with a "V" shaped rabbet join in that area. No one said historically correct ship modeling from scratch or designing a kit of such complexity is easyHello Paul I think you are referring to the area marked with the red arrow. In the Ancre monographs this area is also always V-shaped and not semicircular. I think it should be V-shaped because your planks are also at right angles at the end and not rounded to create a clean transition. You also have this at the bow. See pictures.
Thanks for stopping by Bob. There aren't too many build reports on this kit and I consider it a real privilege to be able to share your production work with the members of our forum. My guess is there are very few of these kits left anymore...Hi Paul, Bob Hunt here. Thought I'd chime in to thank you for the compliment on my kit design. I worked very closely with David Antscherl and Greg Herbert when I designed the kit. I used David's drawings with his permission and also paid him a royalty for every kit I sold. Greg Herbert and I go way back. He provided me with every photo he took when he built the prototype. I attended some special classes with him and David at his house in Maryland and took my prototype model for the class attendees to see.
As you can tell, I used a layering techniques to make easier to build. Those steps for the cant frames on the stern deadwood and the bow inner deadwood are just one example. Once assembled, it looks like it's a part of the deadwood. As a matter of fact, if you look closely at the various parts to the stern deadwood outer layer, they match the inner thick layer so that it looks like it's all one single piece of wood.
The kit required over 2000 CNC milled parts and it took 4 days running one mill 8 hours a day to cut all of those parts out. I had two Shopbot router mills so I was able to produce 2 kits in a week but because I was also producing 3 other kits, the Fair American, the Halifax, and the HMY Fubbs, each kit only got produce once per month. The Kingfisher was the most popular I ever designed and produced by myself and I was always 6 months behind in production.
Alas all good things must come to an end so eventually my wood supplier retired and I had to shut the kit part of my business, The Lauck Street Shipyard, down. However the practicum part is still going and I will celebrate 20 years in business on June 1st. My website is https://www.lauckstreetshipyard.com . I also write articles for the Model Shipbuilder Journal over at the MSB forum owned by Winston Scoville.
Just thought everyone might want a little bit of production history on this kit. I'm please to see you building the kit and compliment you on the fine job you're doing so far. If you have any questions for me, just give me a shout.
Bob Hunt
), so when I get back to the shipyard I might just continue making more of these, or try my hand at some of the more difficult frames.
