Be careful when opening the box before you’re ready to begin construction. kit manufacturers pack something called temptation inside.
I hear you Ron, but no chance of that happening this time around. The WB will be finished first and then there's my caveat of next year's future plans. By my standards the Titanic is a big model, so no construction until I know where I will be.Be careful when opening the box before you’re ready to begin construction. kit manufacturers pack something called temptation inside.![]()
No problem, Peter - there is still some cake left (really!). Thank you very much for the birthday wishes. It is much appreciated!I guess I've missed the party....
Still, the very best wishes for your birthday Heinrich!!![]()
Thanks Dean. It was a wonderful party - full of fun and laughter.Wow! Making me hungry! Great party and friends!![]()
Gotta try matching mail spacing to scale.Dear Friends
As promised, the time has now come to get more serious and to publish the results of the 2012 Russian Expedition. The report below is verbatim in the words of expedition leader, D.F. Kravchenko (unless otherwise noted in which case it will be comments of my own that I have added.
2012 RUSSIAN EXPEDITION - RESEARCH RESULTS:
31.12.2012
Friends! It has been quite a long time since the end of our work on Novaya Zemlya. And although the study of samples and the compilation of gradient maps have not yet been completed, already now much can be "laid out on the shelves".
When an assessment of any work is given, it is necessary to talk about both its results and the mistakes made. Without this approach, the "results" would look dubious...
The tight schedule of the base vessel and the extremely adverse weather conditions did not prevent us from completing most of the planned research. We managed to scan the alleged place of stranding of the caravel of the Dutch expedition of 1596-97, the area of the water area between the first and second reefs. The most interesting results were yielded on the last working day of the expedition. At the edge of the water, at the base of the first reef, 4 fragments of frames that belonged to the bottom part of the caravel's hull were found. These frames had negative buoyancy. The place where they were found was repeatedly checked on prior expeditions when mapping the coastline, but no parts of the hull had been found there before. Most likely, they were thrown out by the waves the day before, during a storm, when the wind speed reached 25-30 m / s.
It should be noted that among the numerous fragments of the ship's hull discovered between 1978 and 2009, all elements belonged to the surface part of the hull and had positive buoyancy. Such fragments could be carried by the current to very remote parts of the coast. Parts of the hull with negative buoyancy can be washed ashore, usually near the location of the sunken ship.
There can be no doubt that the wooden fragments belong to the Dutch vessel, Dmitry Kravchenko himself does not doubt for a second. The composition of the material of the artifacts found (frames) - is clearly from a deciduous tree, most likely oak. The Pomors did not build their kochi and karbas from oak, it simply did not exist in the north. In addition, the method of fixing the nails and the nails themselves, also testify to their Dutch origin.
Measurements of Fragment 2 (wood, oak)
Color: Close to black
Maximum length: 1770 mm
Maximum width: 170 mm
Average height: 100 mm
The cross-section is rectangular, one end is broken, the other is beveled (cut) at a length of 28 cm at an angle of 40 degrees. There are 11 holes for nails with a diameter of about 31 mm on one side of the fragment (the outer side is rolled, rounded), about 29 mm on the inside. They have 4 nails, of which 1 is 1 protruding with a diameter of 28-30 mm. The distances between the nails from the broken end are as follow:
Outer run-in side: 1-2 235 mm, 2-3 195mm, 3-4 210mm, 4-5 190mm, 5-6 220mm, 6-7 100 mm, 7-8 105mm, 8-9 160mm, 9-10 160mm, 10-11 120mm
Flat inner side: 1-2 235 mm, 2-3 185 mm, 3-4 215 mm, 4-5 190 mm, 5-6 210 mm, 6-7 110 mm, 7-8 115 mm, 8-9 160 mm, 9-10 160 mm, 10-11 125 mm.
Degradation of wood is significant - with cracks and chips present. The fragment was presumably under water for a long time and was thrown to the water's edge relatively recently.
Summary:
Expedition 2012 is over. We are waiting for work in 2013.
Happy New Year dear friends "fellow soldiers"! I wish you health, success and Good Luck!
Sincerely yours Dmitry Kravchenko.
Kravchenko (right) and Victor Boyarsky (1992 and 2005 expedition leader on the left) discuss the fragments found during the 2012 expedition.
This is the same Victor Boyarsky whom @Ab Hoving Ab Hoving met during his visit to Moscow in 1993 following the 1992 Russian Expedition to Nova Zembla and the same Vicor Boyarsky under whose auspices the plaque "Mercurius" was attached in 2005 to the fragments found during that year's expedition.
My Summary:
1. At the writing of this report, the Russians were still awaiting the results of the Radiocarbon Analysis of the fragments.
2. 4 fragments of frames that belonged to the bottom part of the caravel's hull were found
To be Continued ...
You lost me there Vic!Gotta try matching mail spacing to scale.
Hi Don - thank you for the question. Since 2005, the Russians are absolutely sure that Barentsz's ship was called De Mercurius (Mercury). Since 2005 already, a fragment of a frame (discovered by the expedition of the Russian Research Institute of Cultural and Natural Heritage under the leadership of Pyotr Boyarsky) and which is exhibited in the Museum of the History of the Murmansk Shipping Company, has been labeled "Mercury". As you can see in all the press reports, the name Mercury has been widely used by all researchers and government departments involved in the research and expeditions.I'm a little confused. How would carbon dating confirm it was the Mercury? We know Barentsz was there but do we know for sure which ship he was on? I thought there was some doubt about that but I may have missed something. If they could confirm from the shape of the frames that it was the Mercury, I think that would be more accurate.
Good afternoon Heinrich. That is all so special. There is no doubt you had a fantastic and rewarding birthday. Stunning gifts……and some delicious oystersThe party was a great one!
This fellow escaped the gallows - well at least as far as we were concerned.
Peking duck - the real McCoy!
Hmmmm ...![]()
. Cheers Grant
Thank you, Dean.Excellent coverage of the expeditions and findings. This has been interesting reading for sure!![]()
Much obliged Johan.A very enlightening exposition of the Russian expeditions.
Worthy of a proper researcher.
