Good morning.
I really do not like the “limey” look of my Xebec. I was hoping to make a wood finish Xebec however there is too much laminate parts and lime. I don’t have Peters skill nor the resources to remake all these parts as Peter
@Ptèr did on his exemplary Cazador.(although with all his bashing and exquisite carvings we will have to call it Peters Xebec
So - I have decided to paint some aspects of “Simons the Corsair,s” Xebec. There are some beautiful examples of painted versions E.g.
@Lologaditano Jabeque Cazador:
I went to go for a browny red almost a “hull red” inner bulwarks. This has been inspired from the Dutch Bloedvlag of the pirates back then. Simon was Dutch after all.
The stern bulwarks reduce by 8mm at the stern and 10mm at the fore part and extend by 20mm. Planked and being painted.
The bulwarks nailed and glued to the hull and cut and fitted some extensions for the stern.
I had to cut out the oar ports as my simulated closed ports did not work with the painted Bulkwarks. This is WIP and plenty of filing and fairing to do.
Decks worked a thin layer of poly applied.
View attachment 359149View attachment 359147View attachment 359150
This is where we are at:
Cheers Grant
