VID_20230107_161517.mp4
**VIEW THREAD HERE** |
turn the lead screws by hand, when the machine is turned on, there should be no play
hi Oleg, you need to rotate the screw itself by hand, otherwise you won’t see anything, it’s these clutches that burst easily, it’s better to replace them with those on the right in my photo![]()
VID_20230108_141504.mp4
drive.google.com
drive.google.com
this is not a bearing, turn the screw, see if the coupling has burst, there are screws on it, loosen, remove the engine and replace![]()
VID_20230108_151254.mp4
drive.google.com
VID_20230108_151428.mp4
drive.google.com
So how can I replace the bearing? Will I be able to knock it out and push back by myself?
