HMS Royal William 1719 1:55 by OlegM
ок, clicks during movement can still be emitted by a screw coupling in the middle of the screw, if there is no lubrication in it, then when the washer is loosened, the balls can jump and click
is that your У axis? check everything already, you don’t need to remove it, just turn the screws with your hands, the damage is visible, if you don’t find any defects, calibrate the axes again
I also finished the molds. First experience, not perfect, but will see how the casting will go. Being a novice, I did the molds too tick, so had to cut away the excessive material from all the sides, otherwise would not be able to cut the mold into 2 halves.
Now just need to cover with graphite powder
