Have a great birthday Oleg. Love following your work!
Happy Birthday OlegI managed to make the 4 guns that I will use for molds. I eventually didn't suceed with the 4th axis. There's something that I don't understand... something is happening and it doesn't work. For some reason I cannot find the 0 of the axes. I go the common way - mill the slot on the side of blank piece, rotate the piece 180deg, mill another slot on the other side of the piece (while it's same bit location). Measure across the flats, divide by 2. If it's Z, lower the Z0 by that amount. If i's Y, add bit radius and mode Y0 by that amount. Should work. But it just dosn't. Had to repeat this operation 3 or 4 times to incrementally arrive to 0. Or more or less 0. But even after that, still doesn't work. Either the peice is deforming, or the bit is deforming, or the 4the axis itself is deplacing or rotating, or I just cannot put the axis straight and align the jaws part with aft fixation, or....
So had to go the usual way, put it on table and manually rotate 180 degrees mid-work. In this way, however, is not possible to completely eliminate the mismatch, if you are lucky, it will be about 0.05-0.1 mm.
And these are unseccessful attempts:
Now need to do some finish at the end, polish, remove the mismatch line and ready for molds.
It would be nice if you get your messages in English, then many of our members would be knowledgeable of your suggestions.Привет Олег, с Днем варенья, будь здоров, расти большой)
на 4-й оси Z0 всегда нужно ставить на ось вращения, только так понимает эту точку постпроцессор, если поставишь на поверхность заготовки, будет чудить, и да, фрезеровать лучше без цапф, потом их врезать, дешевые станки не могут правильно отработать высокий прямой угол при вращения.
удачи.
ок, no problem, сorrectedIt would be nice if you get your messages in English, then many of our members would be knowledgeable of your suggestions.
Thank you!!!ок, no problem, сorrected
Hi Oleg, happy jam day, be healthy, grow big)
on the 4th axis, Z0 should always be set to the axis of rotation, this is the only way the postprocessor understands this point, if you put it on the surface of the workpiece, it will be weird, and yes, it’s better to mill without trunnions, then embed them, cheap machines cannot work out a high right angle correctly during rotation.
good luck.
Yes, maybe later. First I need to find where is clanging noise coming from and repair the machine. I will post a video next days. Then - find a way of how to fix the 4th axis to the table and how to orient it strictly along Xcome to me in WhatsAp, I think we will solve the problem, most likely the axes are not calibrated
I had a case when the clutch on the stepper motor burst, the machine worked, but gave an error on this axisYes, maybe later. First I need to find where is clanging noise coming from and repair the machine. I will post a video next days. Then - find a way of how to fix the 4th axis to the table and how to orient it strictly along X
