Great progress, looking forward to following your build log. I would recommend you watch Pavel’s YouTube build videos. He shows a lot of little hints, techniques and build steps that avoid running into problems later on.I will be working on the keel this week end and update the thread. Thanks for you interest. If the ship goes like the slipway, it will be a pleasure.
So true. As good as this kit is still needs to be dry it.A great start, only 20 more to go. Dry fit, dry fit and dry fit. Last three also need to be glued, but also dry fit, dry fit.Dry fitting is a big PITA but worth all the time it takes.
Jan
Thank you much appreciated.View attachment 376562
They are the backstop for the gunport assembly.
Good morning. I think this kit is so interesting. Seeing Jan (@Pathfinder65 )work on his you are in for a fun time. I will pull up a chair here. Cheers GrantStarted work on the gunwales.
Hope rains tomorrow so I can keep working on it.
Working on this model is addicting.View attachment 376569
