Wow what a great photo. I really like the "Cathedral" look.
Congratulations Daniel. That really looks wonderful! Have a great Easter!Hello everyone, I hit a milestone, all frames are now in place. The transom frames were the most difficult, after dry fitting I had to glue up the end pieces then attach it as a unit to the frame support piece. Well, that required sanding the notches in various locations a little at a time until it slid into place.
View attachment 367737View attachment 367738View attachment 367739
The transom section is not a perfect fit but close enough for final fairing along with the rest of the hull.
Hope you enjoy till next update.
Looks great Daniel! Fantastic job!Good morning once again everyone. Peter @Peter Voogt reminded me to take a look at the cathedral effect. To my eye I would say the alignments created are within an acceptable tolerance. This is about a third of the frames installed so hopefully this trend continues. Check it out.
View attachment 367647View attachment 367648View attachment 367649
More to follow.
Congrats on the first milestone! She looks beautiful! Fun work ahead doing the sister keelson and lower beams!Hello everyone, I hit a milestone, all frames are now in place. The transom frames were the most difficult, after dry fitting I had to glue up the end pieces then attach it as a unit to the frame support piece. Well, that required sanding the notches in various locations a little at a time until it slid into place.
As always an impressive sight, even when partial.Good morning once again everyone. Peter @Peter Voogt reminded me to take a look at the cathedral effect. To my eye I would say the alignments created are within an acceptable tolerance. This is about a third of the frames installed so hopefully this trend continues. Check it out.
More to follow.
Thanks Paul! Happy Easter to you and yours too.Congratulations Daniel. That really looks wonderful! Have a great Easter!
I wondered the same thing Dean, then it struck me how difficult it would have really been without that extra extension, that would mean no flexibility at all for installation, and I am glad it was there (I think).Makes you wonder why they made the frames so tall? It just makes it harder to work inside the hull.
Thanks for the advice, Johan, I think they would be required during the fairing process as well as installation of the lower longitudinal stiffeners in some locations. If there are sections where the spacing is very close to the plan distance, then shouldn't need them.When permanently attaching the frames, it might be useful to apply spacers to ensure correct frame pitches; it did wonders for my build.
Ha! Me make you look bad!!Wow! I think yours looks better than mine did at this stage!
Can you people stop making me look bad!![]()
Dean I struggle just to keep myself from looking like a Kindergartner in the shadow of your work!Daniel,Thanks for the advice, Johan, I think they would be required during the fairing process as well as installation of the lower longitudinal stiffeners in some locations. If there are sections where the spacing is very close to the plan distance, then shouldn't need them.
Your doing a great job thus far! The frame work is very clean and precise. A good foundation for what's ahead!Ha! Me make you look bad!!Dean I struggle just to keep myself from looking like a Kindergartner in the shadow of your work!
Thank you for the heads up, Dean. I just finished gluing in those tiny multibeveled wings #58 to the transom ribs. My next step is to read ahead before I do anything, and I will take special notice of your suggestion.add the waterway boards with all of the notches, it will not be glued, but just put in place as a spacer to ensure all frames are the correct width apart.
Can you stop complaining?Can you people stop making me look bad!![]()
A very nice job, Daniel. And special the transom frames looks very very nice. It are parts that can give you a headache.Hello everyone, I hit a milestone, all frames are now in place. The transom frames were the most difficult, after dry fitting I had to glue up the end pieces then attach it as a unit to the frame support piece. Well, that required sanding the notches in various locations a little at a time until it slid into place.
Well…I could look at Peters BN if I want to be humbled!Can you stop complaining?
Since when is your Bluenose-build inferior to the others?
