This is all a completely fascinating discussion to me. I really look forward to watching this project progress.
Waldemar,.
Many thanks, Marc. Honestly, it could already end here, because I have squeezed everything I wanted to know about this model, or maybe better: I have finally learned the method of designing it with all the details (the upper parts of the ship's hull are already conceptually quite irrelevant).
However, your post may provoke me to carry out a more complete reconstruction. Besides, I should redraw the whole thing, correcting the breadth of the ship's hull to the dimensions of the model. I had previously assumed that it had laterally shrunk more because I was misled by the incorrect model dimensions given on the museum website and the rather inconsistent dimensions given by Glete, especially the keel length.
Basically it will be the same, as the whole geometrical construction remains the same, the shape and run of all the design lines the same, and the radii of all the sweeps the same.
I noticed it already and told Waldemar in private correspondence.
Port side:
Starboard side:
They are still somewhat asymmetric, but closer to the place where they should be.
Also, some internal details obstruct the cable entry from the inside in the _new_ holes, so their place is apparently wrong.
As we explained before, that is a question of dimensions. If the dimensions of the model as we know them are correct, and we assume the scale of 1:48, the ship depicted by the model is larger than the known dimensions of Riksapplet as built. (see post #15)
However the model indeed can and probably have incorporated changes from the English original (including deadrise - if the deadrise was not already present on the original - the shape of the bow and decorations), yet I would wait for Waldemar to make at least a preliminary set of lines before looking at this more closely.
A question from a layman. Do the lumps in the curve of the frames serve a purpose? Stability? Increased storage?.
Thank you Allegheny. Basically, I am looking for information that cannot be found in Bushnell's simplistic Vademecum 1664 or Dean's equally simplistic Doctrine 1670. As can be seen, the practices of the time were already more advanced than those described in period manuals, and on which today's studies of the subject are mainly based.
Maarten, the variable breadth sweeps are already described in the so-called Newton manuscript c. 1600. It should be added here that, at least in the stern section, their use was even necessary for round-tuck sterns. It is difficult to say whether the Sovereign of the Seas 1637 was designed by exactly the same design method with all its details as shown here, but surely the level of sophistication must have already been similar. However, there are still so many period models to be properly researched...
OK, now that everything is clearer to me, and in order not to disappoint the expectations of Martes, who also put considerable effort into this as well as other projects (largely hidden in private correspondence), another attempt with already corrected reconstruction graphics.
This time I will use a different approach. The scanned Ö 3 model will be scaled up to the design assumptions of the 1654 programme ships and inversely to the previous diagrams, further on the dimensions will be given for this size, and in brackets for Naseby 1655. If they are not, the given values should be multiplied by 131/120.
To begin with, the reconstructed master frame design. Compared to the preliminary version, it has a larger radius of the lower breadth sweep. Besides, further reconstruction will also take into account Sheldon's correction of his (or his hired employee's) mistake in plotting the hollowing curves already shown above. The irregular contours of the frames at the keel are proof that this mistake was recognised by the model makers themselves and laboriously corrected individually for each frame, but only in the midship area where the angles involved allowed. One by one, using a knife. Not quite neatly.
Blue arrows
, I will dive-in tomorrow. The Knicks are trying to extend their playoff run, and I am FULLY invested! Thank you for the diagrammatic breakdown, Waldemar.
