Thanks Mark!Great kit Dean, enjoy!
Nice to see how the motor is growing. And adding some personal details, Dean. A great kit for further customizing.It’s becoming a motor…the two halves and bottom joined with one end…
Until next time…![]()
Thanks Peter! Tapering the holes is an option I will try, along with continuing to lubricate the threads. Some holes don't even seem to have threads. It feels like I am making the threads with the bolt on some of the die cast pieces...sigh! Hoping not to break a screw, as they are tiny.Nice to see how the motor is growing. And adding some personal details, Dean. A great kit for further customizing.
By the Duc I mostly tapered the holes. Considering my previous experience. But some oil or wax is a good option.
Regard, Peter
Thank you Daniel! It looks very promising as far as detail goes. I am just adding a little extra detail here and there to enhance it.The detail is remarkable, great job on your painting modifications too!
Just a while and we can hear the roaring sound of that Cosworth V8-engine……..To finish this step, you add brackets to the motor that hold the upper shock, and then slide on the upper shock for now.
The parts were once again all silver. They painted all kit parts a base color, so it’s up to you to add more detail by doing additional painting.
Here is the upper shock as supplied…
However there is a rubber stop that is for when the shock bottoms out. It should be black. So I painted it black, and then added some mild weathering to the metal, giving it a mild varnished look where applied.
Once again, in my opinion, these extra details go a long way towards adding realism.
Now the brackets are screwed to the heads and I painted the black screws to match my bolts.
So this is assembly #6, which will be put aside to start the transmission. Also I put an injector velocity stack on one to see what it’s going to look like. Already getting excited.
Thanks for stopping in…
Soon enough she will get the distributor, plug wires and injector hoses. But that is after the engine and transmission are joined.Just a while and we can hear the roaring sound of that Cosworth V8-engine……..![]()
The painting/brushing looks very good, Dean. In particular at the transmission housing it’s highlighted the details very well.Progress pics of current sub assemblies…
Soon they will be joined, but there is much more to add first!
Thank you Peter! Dry brushing is one of my favorite techniques. This is becoming a fun project!The painting/brushing looks very good, Dean. In particular at the transmission housing it’s highlighted the details very well.
It starts to be a impressive engine.
Thanks Francois! I can only imagine what you would do with it!Wow Dean, that's a nice looking kit. At that scale, you should think about adding working crank and pistons like I did in my 1/12 Alfa and will be doing in my current 1/12 Bentley blower. I know many older 1/8 Pocher kits have working engine innards. A bit of 3d modeling and printing would do it.
Thank you Heinrich! Being a Formula One fanatic, and loving the older models…this is right up my alley!Hi Dean. Congratulations on the added venture. I think the JPS and Gold Leaf color schemes are the truly standout ones from that era. I also favor the Lotus - not because of Andretti or Fittipaldi, but because of Senna who recorded his first race win in one - albeit a much later model, of course.
