Beautiful micro-painting work. Chapeau mon ami.
Pulling up a chair, new follower here.Uwe, maybe you are right.
The log will not look complete if started not from the beginning. So after some fight with my laziness, I decided to start from the start.
1. Amati Kits
I like Amati kits because they provide the freedom to create. The modeler can use parts and instructions from the kit, which significantly reduces the time spent on assembly. However, if one wants to be more creative and has the tools, knowledge, materials, and passion for it, the sky is the limit. The only question in this situation is why wouldn't Amati make special kits for that purpose - just planks and drawings, while the rest could be optional.
So, even before purchasing a kit, I knew that I would replace some parts. But initially, I only planned to make small adaptations.
2. Skeleton dry assembly and conclusions made
After I had just dry-assembled the skeleton I saw two main things:
1. The plywood edge of the keel would be visible on the finished model, and the instruction manual does not offer an organic way to hide it.
2. The bulkheads would require additional fixation to maintain a 90° angle between them and the keel.
Additionally, from the very beginning, I wanted to light the model from the inside. So the dry assembly gave me some ideas on how to conduct wires.
Although I followed these ideas, they appeared irrelevant and eventually, I conducted wires in a different way
3. New keel
The first thing I wanted to change was the keel. Therefore, I designed the visible parts of the keel in Fusion 360 and cut them out. This was an initial version, and I planned to make some slight improvements later on.
Since the final planking offered by Amati resembled walnut, I decided to create a walnut keel to match.
Additionally, I had to make necessary modifications to the kit's plywood skeleton keel. This involved cutting out areas for the walnut parts to fit in and creating pockets for future metallic rods, which would serve as the stand fixture.
Here is the initial version of my substitute walnut keel.
4. Strengthening the skeleton
To eliminate wobbling and ensure straight angles between the keel and bulkheads, I decided to incorporate inserts. However, due to my laziness, I only created 3D inserts for the first four spaces between the bulkheads from the stem and the last four from the stern side. For the remaining spaces, I opted to cut precise rectangular bars measuring 4 mm in thickness.
In hindsight, if I were to do it now, I would likely fill in all the spaces with 3D bulkheads. Although it requires more time to make them, the resulting hull would be much more rigid, making the planking process easier. Additionally, there would be no limitations when it comes to attaching anything from the outside to a hull constructed in this manner. The walls would be thick and rigid enough to securely accommodate nails, screws, and other fasteners.
Here are F360 models of some of the 3D inserts.
5. Final set of details and finished skeleton
Once I finished cutting everything I needed, I ended up with this set of components.
(The round holes in the bulkheads were initially intended for wiring the lighting. However, later I decided against wiring through them as it would have been too complicated during the assembly process.)
After the assembly, followed by some sanding, puttying, and additional sanding,
the skeleton began to take shape and looked like this.
You are absolutely right. Applying a brown wash on top of colored elements I wanted to hit two targets: to enhance the 3D effects and to conceal small imperfections resulting from my supposedly "super-precise" micro coloring skills, particularly in the corners where a thicker wash is accumulated.....but of course adding a glaze or thin paint to accent the 3D effect is excellent.
Jax makes JAX Pewter Black that works on most solder, as well as brass and several other metals.Yet, another challenge awaits me - the solder I used to join the parts isn't blackening with Brass Black. Consequently, if I blacken them, there will be shiny spots on the solder. It looks like I'll have to paint these parts.
Thank you! I will check it for futureJax makes JAX Pewter Black that works on most solder, as well as brass and several other metals.
Peter, thank you for the comment! And I was thinking the same way too!The most beautiful Santa Maria made....Love the details. Really like the way you "dressed" the part you placed above the door and below the railing. I think the hinges are nice but to large in width and the rudder a bit to thick. However, my compliments of how everything comes together. Very nice work so far!
Peter
May I add some thoughts about thisPeter, thank you for the comment! And I was thinking the same way too!
It was a dilemma for me - whether to opt for a slightly more complicated building process or to make it a bit thicker. In all the books about the S. Maria I have, the thickness of the rudder is the about same as the thickness of the sternpost, which is 5 mm in my case. When I tried the rudder from the kit (3 mm), it seemed too thin to me. So the optimal thickness could be around 4 mm. However, when considering a vessel of this size, it's easy to imagine a rudder that is about 300 mm thick. Therefore, I decided to take the simpler approach
And the hinges - in the kit they were even wider. I reduced wideness by 1 mm and calculated it approx according to zu Mondfeld recommendation - see the picture below:
But in general - let me sleep with your ideas, may be I will come to slight update of the rudder eventually![]()
Complete logical! It's not about right or wrong, this way or that way. It's just all about what you think will suit your ship the best.Peter, thank you for the comment! And I was thinking the same way too!
