**VIEW THREAD HERE** |
Hi Bela,Im Beitrag #46 hast du das „Lions-Wrack“ erwähnt und einen einfachen Längsschnitt gezeigt. Gibt es weitere Informationen zu diesem Schiff? Ich konnte bisher nichts finden.
Über Hinweise freue ich mich sehr.
Danke
Bela
Hi Pter,Maarten, it's like looking at a real Dutch shipyard of the 17th century. I love the tools you recreate as well to clamp and hold everthing together. It's just a simple but effective way of clamping. Thanks to you I start to understand the planking method of the hull (Vlakbouwmethode) which is brilliant, simple and effective. No patterns to follow, just to understand the fundamentals. However to execute this method is very very hard to do and you are doing an exceptional good job!
Thanks for showing so far!
Peter
I agreea lot of fun to do this.
The progress of your build is amazing, Maarten. Looking forward how the bow will fit to these planks.After a week in China for bussiness I finally had some time again to work on the Zwaan.
First I made extra boeitangen from some clothspin. Simpel and straight forward but very effective.
The new boeitangen are up to their task while fitting the SB 3rd stern plank.
After fitting enjoying the sweeping lines at the stern section. The 4rd row wil start changing the shape towards the typical fluyt shape at the stern.
More and more poles are added fixating the shape of the planking.
On the inside the planks are held together by small wooden bars nailed to the planking ( in model with a drop of CA)
After also fitting the fwd plank the center plank us made to fit. First fitting on one side, followed by scribing the other side.
An over view of the inside, work in progress.
Work on the PS side started.
A well thought-out approach, Maarten. It's all in the details.In the mean time I have added two plumb lines to my building board. One at the bow to allways ensure the model is level at the table.
A second plumb line I can move between the stem and stern and change in height. This I can use for all types of measurements inside the hull.
To continue the planking a lot of dust was neede to prepare more 2,3 mm thick boards from a billet of pear.
