Very nice table for workig Kurt.
Veselim se slikama Nenade.
Poštovani Barba, nađoh uputstva!! Mojoj sreći kraja nema. Sad sam spreman za nastavak. Postovaću slike napretka ovde i truditi ti se da ubacujem konentare na engleskom (doduše malo tarzanskom engleskom) iz poštovanja prema ostali posetiocima foruma.Pozdrav Nenade
Stvarno neznam da li pistoji Pdf varijanta.
Probaj još potražiti, možda nađeš. Ako se ne snađeš, poslati ću ti ja moje upute, ove koje mi više netrebaju. Meni je još potrebno 4 ili 5 brojeva. Nemam ih namjeru čuvati pa nije problem.
I make few modifications like there is no window on the basment cargo level, now i see is a mistake but in that time ago i was thinking it's a good idea. Patern of the decoration is also different then in manual.Pozdrav Nenade
E super da si ih našao upute, ipak, ako nešto zatreba, samo reci. Brod ti izgleda super, ipak, kao da nisu iz iste serije, barem što se tiče dekoracija na provi i krmi, ali nije prvi put da vidim to. A što se tiče laka, ako malo pobrusiš i naneseš sloj mat laka, trebalo bi pomoć. Ipak probaj prvo na nekom uzorku prije. I samo da znaš, žao mi je što nisam neke stvari napravio kao ti!! To je valjda normalno, ali rekao sam da ću raditi strogo po uputama.
It's great that you found the instructions, but if you need anything, just say so. Your boat looks great, though, as if they are not from the same series, at least as far as the bow and stern decorations are concerned, but it's not the first time I've seen that. And as for the varnish, if you sand a little and apply a layer of matte varnish, it would need some help. However, try it first on a sample first. And just so you know, I'm sorry I didn't do some things like you!! I guess that's normal, but I said that I would work strictly according to the instructions.
I have some doubts about the existence of anklets at that timeI stopped here and decided to continueView attachment 382689View attachment 382690
Hi Frank48existence of anklets
ankle rack
Hi Barba , sorry for taking the liberty to expose my doubt.Thanks Frank
I think there are a lot of such dilemmas on this model, but as I said, I follow the instructions. I also commented on the cannons and the lifeboat.
Olá, não sei em específico o que precisa, mas eu construí meu navio e terminei em 2015, tenho todas as fichas de instruções, posso ajudar de alguma forma.Obrigado por compartilhar esta construção amigo!
Este é o meu navio preferido de todos os tempos, infelizmente quando a coleção foi lançada no meu país eu era muito jovem e sinceramente não acredito que estivesse disponível na minha pequena cidade.
Já faz algum tempo que estou tentando encontrar uma coleção em qualquer lugar, só encontrei algumas, mas muito, muito caras.
Tenho uma coleção parcial, mas ainda precisarei de muitas informações adicionais porque está muito incompleta.
Thanks,Excelente construção, trabalho limpo e organizado.
Vou aguardar ele responder, assim saberei como ajudá-lo.Obrigado,
É ótimo termos outra cópia das instruções, acho que Juan apreciaria qualquer ajuda. Eu faço o que posso enfrentar agora.
