Luczorama is proud to launch a 4-week scavenger hunt giveaway packed with creativity, laughs, and nautical nonsense. Explore historic ships, solve easy clues, and have some fun with fellow builders. Complete weekly missions to earn raffle entries — the more you join in, the better your chance to win a Fram model ship by OcCre! **VIEW RULES HERE** |
LaserThose Pilasters are hard to carve. I had the good fortune of having a laser cutter at the USNA to cut out the basic parts: the column, plinth and capitol, and laser incised lines to follow in cutting the flutes. I believe Bluejacket provides this service, if you provide them with a plan. I will go back and find pictures of the process in the restoration of the 74 gun 18th c. Spanish model of the El Terrible that I did this for and attatch them.View attachment 390953View attachment 390954View attachment 390955View attachment 390956View attachment 390957
Laser cutting is definitely a nice option. We continue to try and improve basic tech. The size was the issue, a little bit bigger and I could have carved instead. Thanks for the heads up, will keep option for future.Those Pilasters are hard to carve. I had the good fortune of having a laser cutter at the USNA to cut out the basic parts: the column, plinth and capitol, and laser incised lines to follow in cutting the flutes. I believe Bluejacket provides this service, if you provide them with a plan. I will go back and find pictures of the process in the restoration of the 74 gun 18th c. Spanish model of the El Terrible that I did this for and attatch them.View attachment 390953View attachment 390954View attachment 390955View attachment 390956View attachment 390957
I think I will use burn carving to complete the fine leaf work, carve for larger stern ordainments. We will see how it turns out. For larger items life the bow figurehead I am going to use molding clay and carving. It will be painted gold either way.After the parts are cut out the detailing can be done with small gouges and/or jeweler's files after they are assembled. The smaller capitol and plinth pieces are glued in place right on top their matching counterparts of the one-piece pilaster. The images are lasered there as a guide.
The acanthus leaf capitols on the Corinthian style pilasters on the stern gallery, of course, require more planning, parts and steps in assembling the completed pilaster. I hope this may be of use to you or anyone else confronted with the same issue as one of probably many solutions.
We just used basswood sheet, colored and finished to match.
On the quarter and stern galleries some of the pilasters are original and some are not.
Pete
Using both iron and dremel toolI particularly like the carving in the taffrail! Do you have an iron with wood burning tips? That's a whole other skill set I've pondered. I may even have a set of unused wood burning tips around my shop somewhere, along with all the other Round Tuits I've never gotten to.
Ship's looking good. Can't wait to see the Squirrel!
Pete
anytime !! happy to help !!!Thanks Clipper Randy! I'm working on "Flying Cloud" now and your post is most timely and will prove very helpful fairly soon. Plus thanks for enlightening me as per the"nibbing strake", as opposed to the waterway. and the following details. I'm using the Mamoli kit with Horace Boucher ( Bluejacket) and Scott Bradner plans and details that I found online. Modifying the Mamoli bulkheads to accommodate the changes has been challenging as are the overall changes to the design of the hull. Measure and ponder exhaustively before cutting once!
I gather by your handle that you are a clipper fan. Any further enlightenment you can pass my way is most welcome! Thanks, PeteView attachment 389033View attachment 389034
Planning on coppering and using salt vinegar solution to slightly patinaOooh! I like it better every time I see it! Especially now with the contrast of the black portions of the hull. The coppering thus far looks great! Something I've been struggling with so far myself to find a solution I'm happy with. Would you discuss yours? and do you have more pictures of your coppering in progress?
Keep up the good work! I find it encouraging.
Pete
What proportions of salt to vinegar? (Or if this is like s French recipe, a pinch to a dollop?)Planning on coppering and using salt vinegar solution to slightly patina
