Actually when I went and checked the pre rigging I had done on the masts I found a couple more wrongly threaded....no excuses but i do sometimes find it difficult to thread them, so appreciate the heads up..
**VIEW THREAD HERE** |
How is the sail supposed to catch wind if the sheets are so tight that the cloth is almost horizontal? I've seen this done on other models, usually galleons. What am I missing here?Great work John, she is coming together quite nicely.
I hope you don't mind, but looking at your last pictures it looks as if the sheets, lanyards or whatever are guided through the wrong side of the blocks; the ropes are running through the side indicated with the orange arrow, whereas I think they should run through the other side, marked with the blue arrow:
It's something I did on another model and couldn't change it anymore without a lot of rework, so to my utter shame it's still there. As a result I became a bit allergic to these kind of hiccups...
Kind regards,
Johan
i guess they set the sails in this fashion to catch the rain to replenish their freshwater stocks.How is the sail supposed to catch wind if the sheets are so tight that the cloth is almost horizontal? I've seen this done on other models, usually galleons. What am I missing here?
Retrieving that water would seem like a problem though...i guess they set the sails in this fashion to catch the rain to replenish their freshwater stocks.
(Don't know if it's true, I like the story, though...)
Very long straws…Retrieving that water would seem like a problem though...
Well, set up a living chain from the bowsprit to the fresh water barrels, a couple of buckets and off to work, let's go.Retrieving that water would seem like a problem though...
Thanks for that...it is one of those builds that makes you think you could do it better second time..but maybe they are all like that..?Beautiful work, that’s an excellent result.
Ratlines: stuff of nightmares...
