Hmmmm.......interesting! Might be worth a try?I'm not kidding!![]()
Thanks Philski,I use it and it helps me!After all,it has 2 rollers!Hmmmm.......interesting! Might be worth a try?
I have one too. They have steel gears now.I HAD ONE OF THOSE WORKED GOOD FOR 3 MOS. THEN THE CHEAP PLASTIC GEARS WENT NOT WORTH THE MONEY, JUST ME. I GOT A BENDER THE KIND THAT THE LUTHERES USE AND IT WORKS NEED TO BE CAREFUL YOU DO NOT BURN YOURSELF IT GETS HOT, VERY HOT. GOD BLESS STAY SAFE ALL DON
Hei Patrick,Micro-mark sells it,the price is $ 149,95.Where did you find it?
my gears are metal, fortunatelyI HAD ONE OF THOSE WORKED GOOD FOR 3 MOS. THEN THE CHEAP PLASTIC GEARS WENT NOT WORTH THE MONEY, JUST ME. I GOT A BENDER THE KIND THAT THE LUTHERES USE AND IT WORKS NEED TO BE CAREFUL YOU DO NOT BURN YOURSELF IT GETS HOT, VERY HOT. GOD BLESS STAY SAFE ALL DON
Curious as to why? It appears to be able to bend wet or steamed planks via a roller systen similar to others mentioned above but on a smaller scale and 90 degrees off the horizontal insteaddont buy again junk pile
OK. I understand why this wouldn't work for you after going back and again watching the above video and actually understanding what it says.I have to assume that it's your great video, too. Thanks.I found that getting a general curve does not help very much. What you need is to create a jig that mirrors the shape you want. Then clamp to this shape heat with a hand dryer , no water, so steam, and you get the exact shape you want.
Shape the plank and clamp in position on the hull, it will set with all the bends and twists.I have a friend that has purchased a rib bending heating coil which he will loan me to see if its worth getting one myself. It will be interesting to see how it works. They claim that it puts more heat on the inside edge of the wood allowing the lignum to compress with little chance of the outside edge splitting. The heat does get to the outside edge But nit as hot. They also claim that you can feel the lignum release making it easier to create the bend. I still feel that i will still have to make a jig reflecting the curve when bending complex curves like at the bow of the ship.
