Après j’ai 2 choses que je ne comprends pas bien . J’ai fini le couple 15 nickel et le 01 et 02.
Je n’ai pas laissé de gras sur les delardements . Ma question est pour Tobias sur la photo avec le couple 15 la largeur à l’air d’être à 10,60mm?
Then there are 2 things I don't quite understand. I finished couple 15 nickel and 01 and 02.
I didn't leave any fat on the delardements. My question is for Tobias on the photo with torque 15 the width seems to be 10.60mm?
To answer your question, my ramen was 11mm wide. I had no possibility to order them with 5.3mm or to make them myself. After gluing the frame halves, I adjusted them to 10.6mm. If you already have the measurement, everything is fine.
Your frames look very good, respect.
