Uses for an old cutting mat
The most important thing I learned about my cutting mats, is don't wipe them with acetone or IPA, as it make the lines go away! :eek::eek::oops:
Can you wipe them with a Lager or Belgian Ale? How about a wheat beer?
Oh...I don't wipe mine at all, it is under glass protection. Once it gained the dust I blow it with my whatchmakers syringe. Thanks for the tip, Kurt. I am on the safe side... ROTFROTF
The 'Mat' guru, said they should be white for the most success, with other colors you may not achieve the same cutting results, but... if you have already done some research, you may have already noticed: there are no other colors, for stripes, other than white, on the Green mats out there. :cool:;)
My green mat has grey markings... maybe that's just because it's dirty... ROTF
But cover you cutting mat with a glass plate for protection when using it makes you a special one. Alien
Oh...I see, you missed the point, no wonder you called me crazy. The true of the fact, that I don't use it at all! I hang it on the wall like the art. A green mat of mine has a special place and respect. :p:p:p:p:p:p :D :D:D:D
