John isn't one I would recommend you get factual information from by watching any of his videos. If you try to correct him or leave a comment questioning a process, he simply blocks you! His builds are only novice amateur and not a good source for accuracy!!!A little break from the build with the holiday weekend... had the son's family in from Lejeune with the new grandson (first one!).
Got the interior planking finished up along with the waterways, stained & varnished. Later down the road, I plan on either framing in the gun ports or painting them black... not fond of seeing all the layers of wood.
And, since these logs are all about the good, the bad, and the ugly... everything's been going good so far, a little too good. Of course, the bad & the ugly both hit like a brick wall. I went to put on my first 2nd layer plank following John Aliprantis' method (using CA), and to say that was an unmitigated disaster would be the understatement of the year. The CA soaked right through the thin plank, and as I was trying to press it into place, my thumbs & fingers were sticking to the planks, and as I was trying to pull them off, chunks of wood were just coming right off stuck to my digits. As Ralphie would say... "In the heat of battle, I wove a tapestry of obscenities that, as far as we know, is still hanging in space over Dayton" I figured I had two choices at that moment... either it was hitting the wall, or I just start laughing my butt off.
So that's where it's at... I'm in the process of sanding that plank back down, dropping back, and punting. I'll either try contact cement, or make up a bunch of clamps & try PVA.
Hope everyone had a great Thanksgiving.
Good evening Frank. Lovely work. Your planking looks awesome BTW. Cheers GrantIt's been a minute, but I have been progressing...
Got the inside of the gun ports blacked out
And the wales are a much bigger pain in the butt than I gave them credit for, but 4 down, 4 to go....
Also continuing some side work on the gun carriages. I was going to paint them red, but with the theme of this ship being wood tones, I thought that may be a little too eye-popping, so I settled on the saddle brown with a red tint to offer some contrast, but not be too loud.
