Hi Grant, once again super clean work, it looks greatGreat addition and I love the green tint
Good morning. Thank you. Cheers GrantGreat addition and I love the green tint
What happened to the "BING, BING, BING"? Ricochet Rabbit!! Love the storage chest hinges. Looking snappy as always Grant!
Good morning Ken x 2. Thank you. There is a long way to go before it looks like a decent boat, however slowly getting there. I have been doing research into these boats, previously a shallop and then called a longboat later in the 18th century. I will post a summary of this however what I was amazed at is the size of these....Up to 54ft on the larger vessels and a loaded boat could weigh several tonsHi Grant, once again super clean work, it looks great
Well done!!Ok enough off the topic - back to Grants Xebec: this morning I could fit the bell tower, pumps and main deck cleat I had previously made. The mast is dry fitted as I like to rig as much as possible off the ship. I did add the cleats for the running rigging to mast - 4 of them.
View attachment 408757View attachment 408758View attachment 408756View attachment 408759
Cheers Grant
Well done!!
Good morning. Thank you Mark and Paul. Cheers GrantStunning work Grant, your Xebec is certainly camera-friendly! Very nice indeed![]()
Grant, hi buddy.Good morning
Rigging Mizzen mast : Firstly a big thank you for Peters (@Ptèr ) marvellous build log which has helped me understand this unusual rigging. I will mostly copy his interpretation of this ships rigging with one or two deviations along the way. Occre’s plan is too simplified and has been tossed.
Grant’s understanding of the Xebec Mizzen rigging.
1. Unlike most square riggers from 1750 the Xebec does not have shrouds, deadeyes etc but a configuration of stays.
2. On the Mizzen there are 2 stays with a block and tackle system to tension these.
3. The stays are secured to the strake on the bulkwark via toggles and the mast via a double rope binding.
Fore stay : There is a double 6mm block from the mast head and a single 6mm attach via the toggle system. I used a 0.8mm rope. The running line is a 0.6mm rope between these blocks
Aft stay : There is a single 6mm block from the mast head and a single 6mm via the toggle system. There is also a 10mm violin block via the middle toggle. The running line runs through these blocks.
I made my own toggles from toothpicks as Occre did not provide enough for a complete rigging rigging process :
The violin blocks where made from a 6mm block and 4mm block:
Some pics nothing is tied off:
View attachment 410583View attachment 410584View attachment 410585View attachment 410586
I have chosen to use cotton rope (have to be careful of fluffing) to keep with my objective of this ship being a little “used” and not not too “modelly “ …….I’m not sure I’m getting there but worth the try.
Cheers Grant
Hi Jan, what Sasha means, is how the violin block tackle is laid (see image below). Both images refer as the Violin tackle, but only the image on the right uses the violin (fiddle) blocks.Wow, I don’t understand all the terminology but to my almost “normal again“ vision that rigging looks fantastic.
Good afternoon Mark. Baai dankie Mnr!!. Cheers GrantThis looks like a plan that is going to come together very well indeed, sterkte Grant![]()
Good afternoon Peter. Thanks. This is why I decided to do the Mizzen first- definitely way less confusing than the other two masts. Again thanks for a brilliant log of your Xebec. I would have been lost without it. Sails…….….…I like that you started with the mizzen mast instead of the fore. The cotton rope looks great. Toggles are nicely done as wel. I don't know about your kit, but mine had some pewter / white metal toggles included that didn't do it for me. I like your's much better!
Keep in mind that the principle of the standing and running rigging stays the same for each mast. Only the Mizzen is a simplified version of the other two with less complexity.
You are doing a great job and fast as well. I'm so curious how she will look with sails.... who is with me?![]()
. I will give it a go…
