- Jan 21, 2022
Thanks for the encouragement.This all looks very promising Bandido! Well done!
Just beautiful BandidoFinished the main rib sections of the kit still have the prow and stern portions to do, the difficult part of building this kit is the lack of instruction, and Illustrations!! There really is none! What they do supply can be confusing to say the least. Enough Wining!
The good thing is the kit is very well engineered all parts fit very well so far and the jig is very good. The rib assembly went well I had figured out how to clamp them in place while maintaining the 6mm spacing between the ribs I decided to install the 3 sets of 6mm spacing blocks supplied with the kit on both sides of the rib when assembling the rib to the keel, I also used a bubble level to assure the rib was plumb, and a square to the alignment marks provided on the jig. The issue I was running into was the wood glue I was using was starting to set before I could clamp, measure and set the rib I found a slow setting wood glue, worked great gave me more time to get things the way I needed them.
The other real annoying step was all the spacer blocks 3 sets each side! a lot of glueing and clamping!! but it did make the Hull real rigid and maintained that 6mm spacing. I am happy so far with the results.
thirty!!
Looking at the picture of the windows they look REALLY CROOKED BUT ACTUALLY THEY ARE MUCH STRAITER THAN MY PHOTOS SHOW
amazing work, very good progressAssembled the lower deck framing really was a pain to get it to fit correctly inside the hull and level!! I also decided to finish the lower inside ribs as the middle portion will be visible. I used a amber Shellac coating looks rustic and that is what I want to achieve!! will also coat the exterior ribs below the hull planking. The rest of the ship I will be using a clear varnish.
