**VIEW THREAD HERE** |
I agree with you, Pete. Most commercially available POB kist come with the fewest bulkheads, but they also come with double-plank layouts. In such a design, filling the entire hull with filler blocks waste of time, IMHO. I would only use filler blocks at the bow and stern (depending on the particular hull).In my opinion the bulkheads on all of the POB models I have made were set too far apart to get a fair run of planks. On POF models, as with real wooden ship construction, the frames are so close together as to be virtually touching side by side, assuring that the lay of the planks runs fair fore and aft and snug top to bottom. Filling in between the bulkheads and fairing the filler blocks reproduces this effect (so it says right here) in effect creating a solid hull to work with. But it's a heck of a lot of work and (as with all modeling) the results aren't guaranteed. You can get an idea from what I've posted so far on my build log, but I won't post any more until I get this tedious process complete (and hopefully sanded shaped nice and fair). Then on to planking, the process of which I'm still mulling over and will be dictated by the outcome of the finished shaping of the hull. If I do a good enough job, I should only need one layer of planks. (Fingers crossed)
Pete
That's definitely the whole idea!Thanks.... I'm definitely enjoying the process..... Every single day is a learning experience..
BMT
We'll see how doable it is ( not sure). I've already looked at some stains. That's my weekend project. Keep you posted...BMTYou've made the process a bit more difficult at this stage, but with patience, it's doable. Make samples first, off the ship, to try out stains and/or finishes, to see what you like best and to get the process in hand, before you commit. You CAN do this successfully. I have painted myself into similar corners and always, somehow, managed to pull my fat from the fire (to mix metaphors.)
(It will be one plank at a time.)
Crack On! Pete
Haven’t posted in a while been traveling, and some other odds and sods…
Primed and ready to go for hull painting.
BMTView attachment 402856View attachment 402857View attachment 402858
I'm a few steps behind you on this build and I think you can help me solve some problems I created. When it came to attaching the outside upper bulwarks there was a joint amidships that I managed to glue in with a significant dip like a flattened V with the arms immediately above the slot for the sponson attachment. I noticed this problem after planking. I increased the bulwark height at that point and sanded until it looked like I had a smooth run. Now, looking at the instructions for sponson attachment, I'm not sure whether the sponson tops should be even with or 1/32nd short of bulwark height.View attachment 408043View attachment 408044View attachment 408045View attachment 408046View attachment 408047View attachment 408048It’s been some time again!
Hull and waterline finished. I'm not happy with ModeExpro Hull Spar Black or Hull Copper Red, as suggested. I should have used Lamp Ebony by DecoArt (flat) and perhaps their Copper.
Showing progress with the sponson sections, water closets , and paddle box sections as they are painted (Lamp Ebony), and sponsons with paddles/hubs are attached.
Water closets need major sanding and shaping. This was my first significant sanding and shaping project, and I think they came out OK. There was some fill in the cracks with some plaster, and then panted.
The next step will be the base, which I will spray flat black so it doesn’t take away from the boat.
Happy Thanksgiving, to those in the States!
BMT
My comment is based on whether you have already attached things to the deck permanently. If you haven't, don't. I entirely agree that the deck should be planked. Since you have the kit supplied deck aboard already, think of it as a false deck and plank over it with 1/32 strip. If you have already attacked everything, remove all of the small stuff - even if you damage it in the process. Then, sand out and imperfections created and plank over the decks. My thought would be to leave the pilot house and pull every thing else. The great think about wooden kits is you can always make partsI have been doing some soul-searching. Thinking about laying some planking thinking about perhaps trying to stain it. Should’ve done more soul-searching before I started on the deck….
BMT
Pete's right! Grace for yourself and your ship. Take the time to make it how you want it to look even if it seems like you just added a month to your project.Just a matter of patience, my friend, with the model and, above all, yourself!![]()
Pete
